Question about Fisher Paykel EcoSmart GWL15
How do I reset my Fisher Washing machine size?
I have replaced the control panel, the motor panel, and the water pump but it still flashes the last wash cycle light and spin cycle light when I press the lid lock and when I press it a second time it turns the machine off.
  • tom cassidy
    tom cassidy Apr 16, 2015
    Hi Karen Paro, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Karen Paro
    Karen Paro Apr 16, 2015
    I fixed the problem, I finally found the instruction sheet that explained how to reset the machine and it's working perfectly now again.
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • Fisher Expert
  • 79 Answers
To set the size switch, turn the power on at the power point and off at the console. Press and hold
WASH TEMPERATURE UP then press POWER. EcoSmart will give 4 short beeps
and the pattern of LEDs will change.
To lock the size into memory.
 Press SPIN SPEED UP, the SPIN HOLD LED is on for 7.5 / 8.0kg (650mm wide).
 Press POWER to confirm the setting and also exit this mode.
Posted on Apr 16, 2015
Testimonial: "THANK YOU that did the trick"
6ya staff
SOURCE:
Dov Dror
  • 641 Answers
SOURCE: Doesn`t finish cycle
Thanks for the information !
Posted on Sep 19, 2007
Anonymous
SOURCE: Washing Machine stopped through cycle and now will not turn on
Unplug!!! NOW! I drained the water using a common garden hose, fill the hose with water and have some device turning it off like a trigger nozzle on the low end. Detach from the supply and put the supply end in the center of the tub under the softener dispenser. take the trigger nozzle off and watch the water drain without cups and buckets. Then wring out the clothes and put them aside, use the hose trick again for remaining water. Now get under the washer and detach and reattach the brown and white lead input to the rinse cycle motor. She is made in France so be gentle. Plug the machine in and set the machine down and turn it on. Push the >> button until you reach the spin cycle if it starts you have fixed it!! Put the clothes back in open a bottle of wine and try again.
Posted on Nov 05, 2007
Anonymous
SOURCE: Fisher & Paykel GW712 washing machine continuously
Out of balance switch could be faulty/ coroded.
have a gw 709 and it had the same problem, out of balance switch had jammed on
Posted on Apr 15, 2009
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 31, 2009
luisa_sgro
  • 713 Answers
SOURCE: My Aquasmart WL80T65D washing machine,
Hi just read your fault.Now from the information in your posting the lights that are on when the machine is beeping are the 3,4 and 8th lights.Now these lights are in a row of 8 lights and you started from the left.So from left to right the lights that are lit when the machine is beeping are 3,4,and 8.Is this correct?If it is correct then the fault on your machine is called COLD VALVE FAULT.The 3 reasons why this fault occurs is, 1st the wiring to the water valves is faulty,the 2nd is the cold water valve is faulty, or 3rd the control module is faulty.Have you or can you borrow an electrical test meter so I can help you narrow down which is causing the fault.Please reply with additional information on the questions and I can help you rectify this fault.Looking forward to your reply.
Posted on Oct 04, 2010
I have a Fisher and Paykel IW811 Intuitive Eco washing machine on which I have recently replaced the pump motor and motor control board. I have reset the size for 650mm.
Switch power off at wall & unplug machine for a couple of minutes. Plug it back in and power on. See if it resets it, If not then you may have a faulty main board or it has been damaged somehow during fitting.
Jan 09, 2017 | Fisher and Paykel Washing Machines
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
Fault 49
The main board is displaying the wrong error
for the problem your machine has.
Fault 49 is water valves error.
The most common problem with AquaSmart is pump faulty
and damaged your motor control board,
Pump and motor control board need replacing.
Jul 31, 2014 | Fisher and Paykel Washing Machines
Fisher & Paykel aquasmart washing machine display panel not working
You need to size set the LCD panel to your motor controller.
1. Press and hold the left SCROLL button,Then press HIGH EFFICIENCY button until two beeps are heard.
2. Press the SCROLL button to select machine size
(600 for WL70,650 for WL80).
3. Press the POWER button to set in memory.
Mar 05, 2013 | Fisher and Paykel Aquasmart wl80t65c
Fisher and paykel GW509 won't power up, pump not blocked, plug loose?
62. (00111110) Phase 5 - Pump Over Current
The Motor Controller module has detected an excessive pump current.
Primary Source: Pump.
Action:
Replace Pump.
Secondary Source: Motor Controller module.
Action:
Replace Motor Controller module.
107. (01101011) Phase 2 to 6 - Motor Controller module Reset Error
The Display Module has detected that the Motor Controller module has reset when
it should not have. This can be due to a Motor Controller module supply
disturbance or microprocessor failure.
Primary source: Motor Controller module.
Action: Replace Motor Controller module.
Red, Blue, Yellow go on the motor
Brown , White go on the pump.
Apr 13, 2012 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel mw512 stops during washing and beeps. the lights for the short wash and rinse stay on. i can reset it by turning it off at the wall and putting it through a rinse cycle. its intermittent,...
12. (00001100) Phase 1 to 6 - Flood Protection Error
The Motor Controller module has found the water level to be above the flood level
and tried to pump the excess water out. (Under extremely high flow rate conditions
the machine may overfill during the "top-up" routine in agitate.) After pumping for
30 seconds, it has been unable to lower the water level below the flood level. Either
the water valves have stuck on and are letting water in at a flow rate that is higher
than the pump can handle, or the pump is blocked and can't remove the excess
water.
Action:
mechanically (remove power from machine).
Secondary Source: .Pump system
Action:
Check pump for blockage and drain hose for correct height and kinking
Tertiary Source: Motor Controller module. (Display Module Phase 1)
Action:
If water valves are being driven on electrically, replace Motor Controller
Mar 04, 2012 | Fisher and Paykel Fisher & Paykel Washer
My fisher paykel GWL11 will not power on. Outlet is working. Just last week I replaced the pump motor and I was doing laundry again. This last time I was doing laundry , it did not fully spin dry the...
Did they add a fuse and fuse holder to the pump motor wiring? If not it may have blown the 6.3 A fuse on the motor control board as mine did before I replaced the pump... Did you replace the pump yourself or had a service man do it? If you had someone replace the pump, a return warranty servicve call is in order. If you replaced it yourself you may need a motor control board...$135 + shipping.. Arggh!
I plan to post my lessons learned on my pump/motor controll bd. problem shortly
Oct 07, 2011 | Fisher and Paykel GWL11 Top Load Washer
Machine water pump continously running on power
problem more than likely faulty triac in electronic board solution : replace motor control board
Feb 25, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel EcoSmart GWL15 Logo
2,096 people viewed this question
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
