Televison & Video Logo
Jakki Dixon Posted on Apr 16, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wat button do I push to hit to set my apex converter box DT502 to a Sanyo remote.
Level 3:
Top Expert:
  • Sanyo Master 76,851 Answers
  • Posted on Apr 16, 2015
Sanyo Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15006956
Points
237762
Programming procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Harrie
Level 3:
Top Expert:
  • Sanyo Master 6,746 Answers
 Harrie
Sanyo Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1285908
Points
83153
You never should change anything to a device you want to control with a remote. The remote should be setup, to send the correct code for the deice. Be aware most universal remotes can't send all the codes the device is working with Most of the time only on / off and switching channels will work. For other things you need the remote of the device. In your case the Apex remote.
1 Related Answer
Steve
  • 3290 Answers
  • Posted on Jun 03, 2011
SOURCE: I have a ge rm24914
You can find a list of supported devices codes for your RM24914 and other GE remotes that require a 4 digit code, here. (a list of device codes for use with GE universal remotes that require a 3 digit code can be found here instead). Additionally, the user manual for the RM24914 can be found here. You will need to download a free program called Adobe Reader to view these files.
I hope this helps and good luck. please rate my reply. Thank you.
Wat is tha apex DT502 code to a Sanyo TV remote?
Jakki. apex DT502 code. 749 or 0749 or 00749 depending on if your remote uses a 3,4, or 5 digit code. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://electrohelponline.blogspot.ca/ http://www.remotecodelist.com/ Codes for Universal Remotes How to Program Universal Remote Welcome to Remote Central Universal Remote Control Reviews More
Does the rca dta800 remote work with the apex dt502 converter box?
No. RCA remote controls (any model) have no set-up code to Apex brand devices. Electrohelponline
RCA rcu410bl on Apex DT502 Digital TV Converter Box
0218 0233 0237 0436 0673. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
Try this link too
Apex dt502 digital tv remote was lost
Go to Remotes.com - Or - you can call 1-800- remotes to get a replacement. The new recommended replacement remote sells for $19.95 and has a large red mute button on it. The old one is no longer available unless you wish to do a good web search or try ebay.
I have a ge rm24914 remote and an Apex dt502 digital converter box. I need a programming code for the dt502.
TRYING TO USE RCA UNIVERSAL REMOTE FOR APEX DIGITAL BOX
If it's not on the list, try the "search for correct code section" on the manual
30helpful
4answers
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
