Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Horizontal hold on bottom half of picture fluttering
When turned on sony symbol on tv moves up and down
    Top Expert:
  • Sony Master
  • 76,177 Answers
Flickering can be adjusted. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Apr 20, 2015
  • Sony Master
  • 1,257 Answers
I would take the back cover off and examine the power supply. You will be looking for bad capacitors. These capacitors will be bulged, you must replace these and any that are next to or akin to the bad capacitors. Start here first. We will start with that, as you may continue to ask. Thanks for asking me
Posted on Apr 19, 2015
6ya staff
SOURCE:
HI, I was wondering if there is way to adjust the horizontal position on the screen of Sony KP-57WV600. By adjusting I mean a way to shrink the displayed picture horizontally or vertically.To give you an...
There is button "Wide Mode" on tv remote, press it repeatedly to select desired zoom mode to view best fit picture in screen.
Click Sony Support link to download user manual free copy and check page-48 for details.
Thanks.
Jan 06, 2011 | Sony Televison & Video
Vizio sp42a
your tv is having a problem of more than one component .to get rid of the problem u should rectify your vif horizontal and vertical sections
Sep 24, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
JVC AV 60D501 H hold ?
What do you mean jumping, or does the picture look like it is in 3-D?
Aug 10, 2007 | JVC AV-60D501 60" Rear Projection...
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Jul 09, 2007 | Mitsubishi VS-60705 60" Rear Projection...
TV goes black at bottom and has horizonal lines in middle?
Hello, please check the high current area around flyback transformer, horizontal output transistor as well as the deflection connector for bad soldering. Best regards, Arpi If you need more info please advice.
Apr 12, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Half a picture
Dont use the set and call a service tech,you might have loose conections in the horizontal circuit,if you keep using it for this problem it might become worst.
Aug 29, 2006 | Sony KV-36XBR450 36" TV
Samsung
By bottom up do you mean that if you flipped the monitor upside down the picture would be right side up but backwards? If so then the horizontal is o.k. since you are reversing it when you flip it. It sounds like it is just your vertical windings of the yoke have had their relative polarity reversed. Could be major or it also could be as simple as some one has put the connector on backwards. Consult your local lab, at the end you're also dependant on their repair estimate. Good luck
May 16, 2006 | Samsung TXK2566 25" TV
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
47 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
