Televison & Video Logo
G
Geoff Hardy Posted on Apr 18, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to connect a hearing device for my father. Needs audio out connections - does this tv have them?
Todd Arndt
Level 3:
Top Expert:
  • Master 2,044 Answers
  • Posted on Apr 18, 2015
Todd Arndt
Master
Level 3:
Top Expert:
Answers
2044
Questions
Helped
583760
Points
5934
What TV Do you have? Make and Model ?
On the Back of the TV unless it is an Analog, there is a AUDIO OUT. This is where you plug in the Hearing Headset Box.
Samsung TV with audio no video
No displays on the TV screen with hearing the sound on your TV could be caused due to. A connection problems which is the main common issues. Or where there is a bad connection or faulty cables or not being hooked up correctly Or a problem with devices being connected to the TV
On my compilot I hear fine if I listen with tv muted, but with tv on (so others can hear) there's a terrible echo and I can't hear
Make sure it is connected directly to the TV audio output and that there is not a microphone connected to the compilot streaming device. If it has an internal mic or a connected one plus a direct connection via a cable there will be an echoing feedback. Remember to check the set up in the manual to make sure it is connected properly.
1helpful
I have a Grundig TV model: GU22WDVD10, my sound has randomly stopped working when connected to my ps4 but works connected to my Xbox? I have tried different HDMI cables and still no sound
does the tv have audio in if yes try this,,,,use your tv instead of headphone ,,,, For the PlayStation 4, you can just use a regular set of 3.5mm headphones to hear game audio through the port on the DualShock 4. To do so, from the PS menu, go to Settings > Devices > Audio Devices > output to Headphones > With yourheadphones plugged in select "All Audio" as opposed to "Chat Audio You can also adjust the volume from Audio Devices > Volume Control (Headphones) - tv. this may work
Audio out locations on back of tv
Hello
You want to connect your TV with an external audio device, and want to hear sound from it, I assuses, and posts this solution.
There is audio out sockets at the back side of the TV, very near to S-Video socket. Marked audio "L" & "R". These two sockets are audio out socketsfrom TV to connect any external audio amp. Just use an audio cable to connect these sockets, to 'Audio IN' of the amp socket. Switch ON both the devices. You can hear the audio of your TV programmes by the amp you conneccted with.
The picture of the AV cable is given here. Take red and White colourd connections to connect the TV with amp. Left the Yello coloured pins free. It is meant for video. 2_11_2012_3_19_43_pm.jpg
Good picture no sound
Hello
Check the speakers first. Get this set connected to an external audio amplifier device, such ans an amplifier or so, with its audio out connections at the back of the TV with audio in connections on the back of the amp, and listen whether you can see sound from the external amp. If you can hear sound from the external amp, and not with the internal speakers of your tv, either the speakers may have damaged or it audio output IC had got damaged. if so you have to replace the IC or should replace the audio card o your tV, if the IC is not available at local electronic spare part market.
If you can't hear any audio by external amp, as it has been connected as stated earlier, the mother board [main board] of your tv has the trouble. There is no repair to this digital board, and it should be replaced as card basis. OK.
2answers
How can I hook up my Bose cinemate on my Philips HD tv when no there is no Audio out and I want to use it for my dvd player, cable box, and video systems?
You don't need to send audio TO a TV. I's a TV, not a source of anything. Many of us use monitors (no TV speakers). The Bose speakers are presumably superior to the TV speakers so whatever the TV is watching (cable/sat/dvd) shuld have its own audio.
Page 11.
If your TV does not have any audio output jacks, you can connect the CineMate™ speaker
system to the audio output jacks of another source, such as a DVD player or cable/satellite
box. However, you will hear sound only from the connected source through your CineMate
speakers.
http://www.retrevo.com/support/Bose-Cinemate-Speaker-Systems-manual/id/526dj591/t/2/
Hdmi will not work only use of component cables will.
Hello
The HDMI[1] input on your TV receives digital audio
and uncompressed digital video and audio from an
HDMI device or uncompressed digital video from a
DVI[2] device.
This input is designed to accept HDCP[3] program
material in digital form from EIA/CEA-861/861B-
compliant[4] consumer electronic devices (such as a settop
box or DVD player with HDMI or DVI output).
The HDMI input is designed for best performance
with 1080i high-definition video signals, but will also
accept and display 480i, 480p, and 720p signals.
To connect an HDMI device, you will need:
• one HDMI cable (type A connector)
For proper operation, it is recommended that you use
a short HDMI cable. You should not encounter
difficulty if you use an HDMI cable shorter than 16.4
ft (5m).
HDMI cable transfers both video and audio.
Separate analog audio cables are not required (see
illustration below). Some CDVs (video CDs) may
not output digital audio signals. In that case, you
may hear sound by connecting analog audio cables.
However, if you connect analog audio cables with
this connection, the HDMI terminal on the TV will
not receive the HDMI digital audio signal and you
will hear analog audio only.
To ensure that the HDMI or DVI device is reset
properly, it is recommended that you follow
these procedures:
• When turning on your electronic components,
turn on the TV first, and then the HDMI or
DVI device.
• When turning off your electronic components,
turn off the HDMI or DVI device first, and
then the TV.
To connect a DVI device, you will need:
• one HDMI-to-DVI adapter cable
(HDMI type A connector)
For proper operation, the length of an HDMI-to-
DVI adapter cable should not exceed 9.8 ft (3m).
The recommended length is 6.6 ft (2m).
• one pair of standard analog audio cables
OK
Hi,I have an old stereo amplifier Model A-604R,and i want to make the most use i could from it..it was my father's!! please help me connecting it,and can i connect it to a T.v?
Yes, if the TV has RCA-audio outputs, but TV audio electronics is hardly hi-fi; or get the TV-related audio from the cable/sat box. They always have RCA outputs. Jack them into the amp's input.
3helpful
Receiver to tv hook-up
Is this a Pioneer receiver? They have the prefix of VSX but I can not locate that model on Pioneers website. It could be because it is an older model and no service information is on the website for receivers older than about 5 years old.
To answer your question I need more information. Do you want to connect the video switching of the receiver to the TV or just want the sound of the TV to go to the receiver? I would also need to know what type of video devices you want to connect and what type of inputs and outputs your TV has.
Most TV's have at least a composite video input, that is the most common type. it is a yellow RCA jack on the back of the TV and will be listed as an "input". That is what would be connected to the video output jack (yellow RCA) of the receiver from the TV for video switching. Then you need video sources connected to the video inputs of the receiver to go to the TV. You also need to connect the audio RCA cables from the video devices to the receiver on the proper video inputs that you have connected. Each video input for composite or S-video has audio RCA jacks (red and white) inputs so you can hear the sound of your video device on the receiver.
If you only want to play the sound from your TV on the recevier, you can use the audio output RCA jacks on the TV and connect them to an audio input of the receiver. This is a very simple way of using the receiver for all the different devices connected to the TV without having to connect everything to the receiver and then always having to have the receiver on any time you watch TV. The audio RCA jacks are always the red and white jacks. you just need to make sure you are using the output jacks of the TV and they are connected to an input jack on the receiver. Then you must switch the receiver to what ever input you just connected the TV to, like the "Video 1" or "Video 2" or maybe "Aux" input.
I hope this helps, but you didn't give much information on how you wanted to connect them.
A good rating would be appreciated if you found this free information helpful.
Let me know if you need any more help,
Dave
Model 60PL9200D/37 no sound
What device is connected to TV: cable, sat box, dvd player? What type of cable are you using to connect to the accessory device?
For a red, white, and yellow cable:
I cannot hear sound from the television when connecting to the AV1 input. What do I need to do?
Answer When you connect the accessory device to the AV1 input of the TV using either component video cables (YPbPr) or composite video cable (Yellow), you must connect the audio output from the accessory device to the 'INPUT AV1 AUDIO L R' of the TV using the RCA audio cables (Red and White).
If the connection is good,
Check to ensure that the AV1 audio source from the TV on-screen menu is selected to AV1.
  1. Press the 'MENU' button on the remote control.
  2. Press the cursor up/down to select SETUP and press the cursor right.
  3. Press the cursor up/down to select SOURCE and press the cursor right.
  4. Press the cursor up/down to select ANALOG AUDIO IN and press the cursor right.
  5. Press the cursor up/down to select AV1 and press the 'OK' button.
  6. Press the 'MENU' button to exit the menu.
Make sure that the volume on the TV and on the device is set at an audible level and also that the sound hasn't been muted.
For HDMI,
The picture quality is good but the TV does not produce any sound when connected to an accessory device with an HDMI to HDMI cable.
Answer
  • The TV's behavior is considered to be normal as some accessory devices have an HDMI audio output setting that requires to be turned on when using an HDMI to HDMI connection.
  • Check the on-screen menu of the accessory device to ensure that the HDMI audio output is set to ON.
  • In some cases, you may need to set the digital out audio stream of the accessory device to PCM.
  • For detailed information, please refer to the user manual of the accessory device.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
