Question about Nintendo Wii Console
Cannot get cursor on screen , replaced sensor bar , but no joy ??
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 55 Answers
Does your Wii connect with your wii-remote(1 blue light on and not blinking)? If not try re-sync the wii-remote:
http://www.wikihow.com/Synchronize-a-Wii-Remote-to-the-Console
Posted on Aug 28, 2015
6ya staff
SOURCE:
Cant get the cursor to show on screen
Make sure that your Sensor Bar is connected properly and that there is no damage to the wire connect it to the Wii.
You may have to place the Sensor Bar else where and reconfigure it to work again.
Ref: http://www.nintendo.com/consumer/systems/wii/en_na/ht_system.jsp
-Connect the Sensor Bar under Wii Console in the left menu.
Dec 19, 2012 | Nintendo Wii Console
I cannot get my Wii remote to move the cursor so I can click on to the net flix channel. What button do I push?
The WiiMote cursor is moved by you pointing the WiiMote at the screen. The cursor will move based on the signals it receives from the sensor bar, which shoudl be placed at the top or bottom of your TV.
May 15, 2011 | Nintendo Wii Sports for Nintendo Wii
NOT ABLE TO SEE THE LITTLE HAND?
If you can't seen the cursor on your TV, the problem is either with the Wii Remote or the Sensor Bar. Try changing the batteries. If you still can't see the cursor, then the problem is with the Sensor Bar. Go into the Wii Settings and adjust the sensitivity of the Sensor Bar, that should solve your problem.
Jan 06, 2011 | Nintendo Wii Console
Have re-booted, re-synced numerous times, held red button simultaneously, one at a time, etc. Everything with the remote works except the cursor. Can move to the right and left by using the +/- buttons,...
Your sensor bar is messed up a replacement on ebay is less then $6. Your controllers arent the problems. Also do you have the sensor bar ontop or bottom of your tv? Theres a setting on the wii to change the sensor bar from top or bottom of the tv depending on where youve put it. 99% sure its a bad sensor bar though.
Nov 25, 2010 | Nintendo Wii Console
Wii remote cursor not showing on screen
My only idea is to check the batteries in the sensor bar. Placement of the bar (above or below the TV) never had an impact on the cursor in my experience.
Jan 03, 2010 | Nintendo Wii Console
The cursor doesn't come up on my screen but the joystick does connect. I have reset and reassigned the joystick but still no cursor
Your sensor bar settings may be messed up. Try moving the sensor bar to the opposite position of where it is (if it is underneath the screen, move it above, and visa versa). If this is the problem go to your settings and just change the sensor bar setting to it's correct location.
Dec 14, 2009 | Nintendo Wii Console
Wii Cursor Does Not Appear
I had the problem where the cursor worked on the main menu screen, but disappeared once you entered any of the channels or a game. For me the problem was a faulty sensor bar. You can check if your sensor bar is working by focussing a digital camera on the bar as if you were taking a picture of it. In the viewfinder you should see 5 blue lights illuminated on both ends of the sensor bar. For me, only one side was illuminated. The sensor bar had to be replaced.
Dec 26, 2007 | Nintendo Wii Console
Cursor does not appear
exchange it
    Cursor not appearing
    Please note that our experience shows that this troubleshooting is best performed using only one (1) Wii Remote at a time.
  • Some games do not use the cursor feature of the Wii Remote; Make sure the game you are attempting to play uses the cursor by reading the game's instruction manual. You can also exit out of the game to return to the Channel Menu and use the Wii Remote to see the cursor. If the cursor still does not appear, continue with the steps below.
  • Trying to use multiple Wii Remotes in the Mii Channel or Photo Channel? These Channels only allow the Wii Remote designated as "Player 1" to function.
  • Verify that the Wii Remote's pointer lens is free of obstructions and contamination (stickers, heavy smudges, etc.). The pointer lens is the tinted rectangle at the end of the Wii Remote.
  • Check the battery power level by turning off the Wii console, then opening the battery cover of the Wii Remote. Press and release the red "SYNC" button to check battery strength. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength. Our experience has shown that as your battery strength decreases to one (1) or less lights flashing, the cursor may not appear. For troubleshooting, if possible, try using fresh batteries so that all four lights illuminate. For guidelines on using batteries, please click here. If after inserting brand new batteries, you are still seeing less than all four LEDs flash, then your Wii Remote will need to be repaired. Please click here for repair information.
  • Is the Wii Remote properly synced?
    Press the POWER button on the Wii Remote to see if the Wii console powers on.
    • If it does, the Wii Remote is synced with the system. Please skip to the next section.
    • If the power doesn't come on, power on the system manually and try syncing the Wii Remote.
      • If the Wii Remote will not sync, there is likely a problem with the Wii Remote. Please click here for repair information.
      • If the Wii Remote will sync and the cursor still does not appear, try another Wii Remote if possible.
        • If at least one Wii Remote is working, there is likely a problem with the first Wii Remote and it will need to be repaired. Please click here for repair information.
        • If you have only one Wii Remote, or none that are working, please continue troubleshooting.
  • Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup).
  • Check the cord on the Sensor Bar for any frayed wires or kinks, and verify that the Sensor Bar is free of obstructions.
  • Check the button functionality, and that the Sensor Bar is operating correctly, by accessing the Wii Main Menu. Use the "+" and "-" buttons to scroll side-to-side through the Wii Channel screens.
    • If you are able to scroll with the "+" and "-" buttons, but the cursor is not appearing, then there is likely a problem with the Sensor Bar. Please click here for additional Sensor Bar information.
    • If there is no response, there is likely a problem with the Wii Remote. Please click here for repair information.
Dec 11, 2007 | Nintendo Wii Console
Wii remote controll
Buy a new sensor bar. None of my 5 Wii remotes had a cursor on screen so I bought a new sensor bar and it worked fine.
Nov 12, 2007 | Nintendo NES Remote Control
Nintendo Wii Console Logo
91 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Ekse
shevantha perera
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
