Maytag Neptune MAH5500B Front Load Washer Logo
Brian Cameron Posted on Apr 19, 2015
Is there a filter to clean on a maytag neptune washing machine
John Robinson
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 29, 2023
John Robinson
Contributor
Level 1:
Answers
Questions
0
Helped
1957
Points
I always leave the door cracked open so air can circulate in there and dry it up till there is no mold I've never had a problem I've had this washer 17 years
5 Related Answers
Amigaman
Gerald Griffin
  • 248 Answers
  • Posted on Oct 21, 2007
SOURCE: maytag washer door boot
   Remove 2 screws holding door hinge to cabinet and remove door.  Then remove 2 screws opposite these. Grab front panel with thumbs at area of screws you removed and pull outward with thumbs. Panel will pivot forward.  Remove panel from lower clips.  At top of exposed area remove 2 5/16 screws.  Remove brackets under them.
  Open dispenser and remove 4 screws.  Careful not to drop in dispenser.  Remove dispenser frame assembly.
  You can now raise top of washer to a 90 degree position.
   Now back to front exposed area.  Grab boot where it contacts front and peel out of groove.  Also remove two screws holding light assembly and remove cover.  Remove all 5/16 screws holding front assembly and the ones on top area where it is on a bevel.  Remove front assembly by folding up and onto top.
  Now we are at the boot.  Remove spring and wire assembly holding boot to drum.  Make note on boot position and spring position.  Remove boot.  Install new boot onto drum.  wrap wire around drum with ends at top.  Now the fun!  Hook spring to on end of wire and using vise-grips,  pull to other end to hook into wire.  It can be done,  honest.
  Now just reverse to reassemble.  should be instructions with boot.   Good luck!
Anonymous
  • Posted on Oct 10, 2008
SOURCE: Repairing leaking Maytag washing machine
Maytag Appliances are ****!! Don't buy Maytag. Spent $2500.00 in 2005 on Maytag Neptune washer and dryer. They have been nothing but trouble. Washer has water running in tub constantly. Recall on ground and recall on footing. Dryer making loud noise when drying clothes.The Maytag man is dead and gone.
Anonymous
  • 62 Answers
  • Posted on Nov 09, 2008
SOURCE: black mold on rubber seal
youust replace it, and start from scratch. From day one you have to maintain the boot with Affresh, whipe out water
Mike Schneider
  • 245 Answers
  • Posted on Jan 25, 2010
SOURCE: My Maytag washing machine leaves residue (lint? soap?) on clothes
us liqwid soap us les chang filter.to meny close can trap the dry stuf.
Anonymous
  • Posted on Aug 16, 2010
SOURCE: RUBBER LINER COLLECTING MOLD
I have been struggling with the same issue for a long time. Regular bleach and mold-killing products did not work. But I just tried Clorox "Washing Machine Cleaner" and was amazed. I scraped off the loose mold from the rubber gasket and then painted on the product, which is thicker than bleach. After about 20 min. I scrubbed it down with water and painted a second coat on the tough areas. No more mold. I also ran some through the machine per the instructions for good measure and ran another rinse cycle. I am in no way connected to Clorox, but I am so happy to be rid of this problem. Good luck. <!-- from fixya rte -->
My husbands wedding ring fell into the lint trap of our Maytag front loading dryer. Anyone know how we can get it out?
You can remove the lint filter to retrieve the RING, please do not put the machine to any wash until the filter and drain pump is removed and checked.
check this link.; Cleaning lint filter
Acquire screens for maytag MAH5500BWW
how to clean filter on maytag neptune front load washer
2answers
My washing machine sounds like it still has water in it when i spin it and it smells musty
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Maytag Neptune Washer - bleach and softner do not empty or have water left in them - how do i fix?
    clean water inlet filter,then check to see if the outlet tubes from the dispenser to the tub are blocked or partially blocked with detergent.
    I use liquid detergent... no problem.
    Cheers
    2answers
    Won't spin or drain, have tried to rerun cycle and checked drain hose
    Check pump / outlet filter , refer to instruction book , clean and replace then re- try
    4helpful
    Neptune
    Remove the water hoses from the washer and clean out the filter screens in the water valve.
    Maytag front load washing machine Model MAH5500B misses spin cycle
    either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
    Maytag Neptune doesn't spin at end
    Of course, did you find anything clogging your outlet filter, this is most likely the problem. The outlet filter needs periodic cleaning, according to your usage.
    Top Maytag Washing Machines Experts
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    ZJ Limited
    ZJ Limited
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
