Question about Maytag Neptune Washing Machines
The LE error code keeps flashing why? - Neptune Maytag Washing Machines
  • 382 Answers
LE means level error. The water fill timer timed out before there was enough water in the machine to clean the clothes. Try this:
  1. Turn the hot and cold water supply taps, located at the end of the fill hoses, as far as they will go toward the "Open" position.
  2. Move the washing machine away from the wall, and examine the hot and cold water pipes for kinks, twists or other obstructions.
  3. Unscrew the fill hoses at the washing machine, and inspect the small plastic screens inside for signs of an obstruction.
  4. Check the water pressure in your home; a reading lower than 30 psi might cause the fill times to extend beyond the time the washing machine is programmed to wait. Slow flowing faucets and shower heads are a sign of low water pressure.
  5. Call for service.
Posted on Apr 20, 2015
Anonymous
SOURCE:
Morris washing machine LE error code flashes
The LE error message means "locked motor error" which means the control is not seeing the motor running. The problem can be caused by a broken wire or loose connection but the most likely cause of the problem is a bad hall sensor.
Dec 22, 2016 | Washing Machines
Washer keeps flashing LE
Hello there and welcome to fixya
this could be a possiability of several things but please try this first
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine due to using too much soap.
Overloading the wash with too much laundry may also cause the LE error code.
And finally , a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened.
Nov 16, 2013 | Samsung WF337AA Front Load Washer
Lg wm2101hw code le
Press "end of cycle" for 3 seconds or till the flashing goes off . Plug off the wall. Code can be an indication of several issues. The most common cause is over sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Click helped if helped.........
Mar 15, 2013 | LG WM2101HW 4.0 cu.ft. Washer
Le keeps flashing
le code is a motor error either you have a broken wire between the door or the motor is bad
May 12, 2011 | Samsung Dishwashers
LE error keeps flashing on screen - won't start wash even though door is closed
LE error - is a water level sensor level fault, you need to check your pressure switch
Jan 13, 2010 | Washing Machines
Stops and flash le code
Le is a locked motor error.  Sometimes glass, or food gets stuck in the bottom of the sump jamming the motor.  Take it apart from the top to check for clogs.  When you get to the impeller the screw might be reverse thread.  If there is nothing stopping the motor, you will need to replace the motor.
Dec 19, 2009 | Washing Machines
Error Code LE on LG Tromm WM2277HS
Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective
Sep 14, 2009 | Washing Machines
Problem with LG washing machine Model number wm1480fhd. The machine drum reluctantly turns and in about a few minutes it displays error code LE (flashing).
LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
Aug 22, 2008 | LG Washing Machines
LE Code on control panel
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Dec 31, 2007 | Washing Machines
LE trouble code
The LE error code can be an indication of several different issues. The most common cause is over-sudsing in the machine. Many times owners experiencing the LE error code are using regular detergent. It is recommended to use a high efficiency or low sudsing detergent. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause the error code. This can occur if there is a loose wire, dislodged ball sensor, or if the shipping bolts are removed prior to situating the washer. Good luck!
Sep 13, 2007 | LG 24 in. LDS 5811ST Stainless Steel...
Washing Machines Logo
296 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
