Question about Cisco Small Business WAP4410N WirelessN Access Point PoEAdvanced Security (S7271261)
Unable to login to WAP4410N using web based administration utility after factory reset. it's reporting as invalid username or password
    New Friend:
Please see the Reset the Default Factory Setting please read it the Detail I have a WAP4410n wireless access point, I have reset it to factory default by pressing the reset button for 30 seconds. I am able to ping its default ip 192.168.1.245 through its default ssid "ciscosb" if I configure my static ip was solved by connecting through the lan cable, and setting manually the ip to 192.168.1.0/24 network, and accessing 192.168.1.245 through web, the reason why the connecting through WiFi was working because the management web access through wireless is disabled by default
Thanks
Posted on Apr 30, 2015
6ya staff
SOURCE:
Deracam will not reset. How do I get it to reset?
If you want to reset your IP Camera to factory defaults, you can use the following 3 methods. After resetting the device you will lose all your settings except Client Settings.
Method 1:Hard reset/ By pressing the RESET button
Step 1- Keep the device powered on for at least 30 seconds to complete its normal startup.
Step 2- Find something like a pin to press the Reset button on the camera and hold it for 15 seconds to restore the settings to factory defaults.
Step 3- Afterwards release Reset button, and the camera will be restored to factory defaults after rebooting.
Note: Reboot process takes about 1 min, please be patient.
Method 2:By using Intelligent IP Installer
Step 1- Install the Intelligent IP Installer with the CD.
Step 2- Run the Intelligent IP Installer. Click Search to find your device.
Step 3- Select your Camera in UPnP device list, click Factory default on the right side.
Step 4- Type the username and password in the login page, the default username and password are both admin. Wait for the device to reboot.
If you changed the username and password before and forgot the username and password, you have to follow
Method 1, make a hard reset.
Method 3:By using Web-based Utility (management page)
Step 1- Open the web browser and type the IP address of the IP Camera into the address bar, press Enter. If you have changed the default port number is 80, Then type the IP address of the camera: new port number into the address bar of web browser.
Step 2- Type the username and password in the login page, the default username and password are both admin. Then click OK to connect to the device.
Step 3- Click SETTING -> BASIC -> Initialize on the left side, and then click Factory default to reset this IP Camera to the factory default settings.
Step 4- Keep waiting until the progress bar shows completion.
Feb 04, 2018 | Miscellaneous
Tip
How do I reset LinkSys Router Default Password?
When you forget your Linksys router password, you will need to reset it back to the factory defaults. You can restore the router configuration to back to the factory by following the steps outlined below:
1. Hold in the reset button of the router for 30 seconds. 2. Unplug your power cord for 30 seconds 3. Plug back your power cord4. Wait for a few seconds then release the reset button.
NOTE:¨ When holding in the reset button, make sure that you do not release it until you are sure that it has been compressed for at least 30 seconds or more.
¨ This procedure resets the router back to all its factory default settings thus apart from affecting your username and password, it will also affect your configuration and IP addressing.
Once this is complete, you can now login and reconfigure your password. To do this:
1. Connect a PC to one of the Linksys router Ethernet ports
2. Open your web browser and go to the URL http://192.168.1.1. This will take you to a web page with a popup box which asks you to enter a username and password to login required to login to your router
3. On older LinkSys routers, the username is set to blank and the password is set to "admin" (without the quotes). On newer Linksys routers, both the default username and the default password are set to "admin".
4. Click on login. You have logged in to the Administrator account and are now able to access and change a number of configuration options for your router.
5. Click on management tab then change your administrator password to any password that you like. Remember to choose a strong password that others cannot guess but that will be easy enough for you to remember.
6. You can also choose to reconfigure other aspects of you Linksys router at this point.
on Nov 25, 2010 | Computers & Internet
Tip
How To Reset Your Linksys Router Password
If you have forgotten your Linksys router password, the easiest thing to do is to reset your router to the factory default settings and then go through the router setup process.
  1. To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
  2. Once your router is hard reset, you will need to login and go through the router setup process.
  3. To reconfigure your Linksys, connect a PC to one of it's Ethernet ports, load a web browser, and go to http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
  4. On older Linksys routers, the default username is blank and the default password is "admin."
  5. On newer Linksys routers, both the default username and the default password are set to "admin."
  6. Once you are past the login screen, you are able to reconfigure the Linksys router.
  7. Go to the management tab and change the administrator password to keep others from accessing your router.
on Jul 12, 2010 | Computers & Internet
Careers24 login reset
these are basic steps but change sometime according to router configuration. If you uses linksys than go for it :
Access the router's web-based set-up page( Enter 192.168.1.1 (admin in the Password and blank for username))
Administration tab > Management >Router Password
Save Settings.
Apr 23, 2014 | Computers & Internet
I have no wepkey to network the problem is anyone can browse connecting to my network using wi-fi
  • If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
    Once your router is hard reset, you will need to login and reconfigure it again.
    To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
    LinkSys Default Password
    On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
    Once you are past the login screen, you are able to reconfigure the LinkSys router.
    You want to go to the management tab and change the administrator password to something else to keep others from accessing your router.
  • 3
    After changing the administrator password then you will need to enable WEP or WAP security so your nosy neighbors aren't tapping into your wireless network. I am picking up 4 networks with my pc antenna.
    Good luck
  • Mar 12, 2011 | Linksys Wireless-G Broadband Router
    I want connect my ipod to the internet but i need a password for my broadband router. The password is for 2wire005 but i dont know my password
  • 3
    Hope i was helpfull.
    I have done a hard reset for my router, I tried the suport page but it did not help... I want to know the default username & password.
    To access the web-based utility, launch the web browser on your computer, and enter the Gateway's default IP address, 192.168.1.1, in the Address field. Then, press Enter.
    A login screen appears. Use the default user name and password, admin, unless you have changed them during the Setup Wizard. (You can set a new user name and password from the Administration tab's Management screen.) Click OK to continue.
    You may refer to WAG200 User Guide if required. (Page-5&7)
    Feel free to contract me for further assistance
    Hope it helps! Good Luck!
    CreativeTECH
    Feb 14, 2011 | Linksys WAG200G Router
    Need to reset my Linsky Cisco wusb54gc
    When you forget your Linksys router password, you will need to reset it back to the factory defaults. You can restore the router configuration to back to the factory by following the steps outlined below: 1. Hold in the reset button of the router for 30 seconds. 2. Unplug your power cord for 30 seconds 3. Plug back your power cord 4. Wait for a few seconds then release the reset button. NOTE: ¨ When holding in the reset button, make sure that you do not release it until you are sure that it has been compressed for at least 30 seconds or more. ¨ This procedure resets the router back to all its factory default settings thus apart from affecting your username and password, it will also affect your configuration and IP addressing. Once this is complete, you can now login and reconfigure your password. To do this: 1. Connect a PC to one of the Linksys router Ethernet ports 2. Open your web browser and go to the URL http://192.168.1.1. This will take you to a web page with a popup box which asks you to enter a username and password to login required to login to your router 3. On older LinkSys routers, the username is set to blank and the password is set to "admin" (without the quotes). On newer Linksys routers, both the default username and the default password are set to "admin". 4. Click on login. You have logged in to the Administrator account and are now able to access and change a number of configuration options for your router. 5. Click on management tab then change your administrator password to any password that you like. Remember to choose a strong password that others cannot guess but that will be easy enough for you to remember. 6. You can also choose to reconfigure other aspects of you Linksys router at this point.
    Nov 25, 2010 | Linksys Computers & Internet
    Gmail id - manzsherif@gmail.com I was able to login to Google/gtalk/orkut with valid username/password. However all of sudden I am unable to login with valid username or gmail id with valid password. i...
    TRY THIS SIMPLE STEP... CLICK "FORGOT PASSWORD" TO GAIN PASSWORD... PROVIDE THE RIGHT INFO. THEN GO TO THE E-MAIL ADD. YOU HAD PROVIDED.. SIMPLE
    Sep 21, 2010 | Google Talk
    Redrose90049@yahoo.com
    Reset There are two ways to reset the Router’s
    factory defaults. Either press and hold the Reset
    Button for approximately five seconds, or restore
    the defaults from Administration > Factory
    Defaults in the Router’s web-based utility.
    How to Access the Web-Based Utility
    your computer, and enter the Router’s default IP address,
    A login screen will appear. (Non-Windows XP users will
    see a similar screen.) Leave the User name field blank. The
    first time you open the Web-based utility, use the default
    password admin. (You can set a new password from the
    Administration tab’s Management screen.) Click OK to
    continue.
    Jan 04, 2010 | Linksys WRT160N Wireless Router
    Cisco Small Business WAP4410N WirelessN Access Point PoEAdvanced Security (S7271261) Logo
    783 people viewed this question
    Top Cisco Computers & Internet Experts
    Prashant M
    Prashant M
    Ekse
    Jeffrey Groves
    Jeffrey Groves
    Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
