Question about Hoover AAA140 Front Load Washer
When emptying machine after spin water vapour coming out of drum
    New Friend:
  • 22 Answers
Hi Steven,if its not having a burnt smell it must be just water vapor,I Iive in this tropical part of the globe so we don't see much of this vapors coming out of our washing machine after spinning..I hope its just some kind of temperature difference and not an expensive problem.Its ok to tell us more of what you are observing,have a nice day amigo !
Posted on Apr 21, 2015
Anonymous
SOURCE:
Hi, I own a Whirlpool Thin Twin Model# LT5000XSN1. I bought it used from a CRAPPY dealer (worst mistake EVER), since day one, we have had an issue with the spin cycle. The cycle will agitate then when the...
This sounds like a classic clogged empty pump issue. The empty cycle is timed and then it steps on to the spin cycle. The machine won't spin if there is still water in the bottom of the drum. When you reset it to a spin cycle again, you are making it run through the empty cycle again, finally getting rid of the water that the clogged filter could not evacuate on the first attempt.
You need to clean the empty pump filter. Now... Where is the filter???? Hmmmm... not sure. It MAY be behind a little panel in the front of the machine near the bottom. I can't find a picture of the machine on the net so I'm not sure.
Clean the filter, I'll bet your problem goes away. You have to wonder why the idiot who sold the machine to you hasn't suggested this!
Jun 21, 2011 | Washing Machines
Have a Kenmore Elite top loading machine and the water starts to fill the drum and it empties out as it fills, so the drum only fills half way. No agitation or spin. Because it just sits there with the...
this sounds like the fill up censer is blocked up,,,its a cheep fix,,, its only a pipe that fills with water and at a set point it stops filling the washer, but if the pipe is partly blocked it throws its self into a wobely?? and thinks its over full so it starts to drain this water out
a good pear of lungs should blow any muck out this pipe
Jun 06, 2010 | Washing Machines
Wont spin
Probably down to the water not emptying from the machine in the empty cycle and the machine won't spin because there's still water in the drum. If this is the case, the root of the problem is almost certainly a blocked filter, restricting the draining of the water and not allowing it all to pump out in time during the empty cycle. You probably need to find and clean your filter.
Feb 02, 2010 | Washing Machines
Wont go into spin cycle
will the drum go round when on a wash. and is it drianing water out if the drum goes round its not your brushes. if it not emptying water you pump as gone and will not spin if there is water in the drum
Jun 28, 2009 | Kenmore Washing Machines
Changed brushes still wont fast spin and empty water
Let me ask you who told you to change the brushes... Im curious!
Jun 10, 2009 | Washing Machines
Washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
Dec 12, 2008 | Tricity Bendix AW1400W Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Hoover ab130 water won't empty from drum
unselect the option button "crease guard or easy iron" it will will spin normally! (ex hoover engineer)
Jan 08, 2008 | Hoover UltraCare HC6 130M Front Load...
Hoover AAA140 Front Load Washer Logo
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
