Alcatel One Touch Fierce Logo
A
Anonymous Posted on Apr 22, 2015
The sound on the alarm don't sound all of the voluns are on hi can you help
kitty cat
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 48 Answers
  • Posted on Apr 22, 2015
kitty cat
Expert
Level 2:
New Friend:
Night Owl:
Answers
48
Questions
Helped
9434
Points
157
If you have any apps that boost your device, try adding the alarm app to the white list so it won't force stop your Alarm.
How to fix mr ring volume on my citris
First go to your home screen thenclick setting which is on the button beliw the click sound then clickmedia volune ingtone Y
6helpful
2answers
My 2001 Mercury sable will not start and when I tried to jump start still wont start but alarm goes off and windshield wipers go haywire could it be the starter?
It could be the starter, but i would start with having your battery load tested. Sounds like that is the problem. I hope this helps.
1helpful
Vw passat alarm does not sound but lights still flash! Also a clicking sound can be heard when car locked,is this related to the same problem?
my 98 passat estate has a fob with the drivers key which activates the alarm in the boot,bit like an immobiliser, just put it in the hole located near or on the alarm,should hear it beep.don't know if its a factory fit alarm.hope this was helpful.
1helpful
SOUND GOES UP AND DOWN WITHOUT TOUCHING VOLUME CONTROL
USE SOME SPIRIT OR WHITE PETROL ON THE VOLUME CONTROLER ITS JUST BECAUSE OF MOIST TURE AFTER USING SPIRIT TURN THE VOLUNE CONTROLER TO END AND TO MIN TWO THREE TIMES
Lanzar subwoffer speaker keeps flaping when volune is raised
x over frequency sounds wrong , level match head unit to amp , see amps gain , turn it all the way counterclock wise first then check , check surround on sub .
1helpful
My system's max volume has dropped significantly, anyone else had this issue?
usually when this happens it means that the sound amplifier in your system is fried which is usually causedby having it at max volune all the time
Speakers in my Hitachi 42HDT79 plasma tv are at full volume even when the volune control is at the lowest setting. What can i do to fix this?
Same thing happend to me, this is not a fix but a work around.
If you have a surround sound stereo use the fiber optic output
for your sound.
Then in the menu selection audio turn off the internal speakers.
Sony CD Walkman-(portable Radio -CD player)Very low sound output.
Problem solved by trying another set of headphones.
Thanks anyway.
Gerda
I lost the volune to my tv. i have no sound. i moved to one room to the livingroom and i lost the sound
Are you using a cable box/satellite box/home stereo system/etc? If so you most likely have the cables connected incorrectly. How do you have the cables set up?
1helpful
Ringing
Hi I just took the batteries out and it sorted itself out, thanks
Top Alcatel Cell Phones Experts
NOEL
NOEL
nexrad_chris
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
