Question about Splendide 2100 Vented Washer-Dryer
Kariba WD 802, need a part number for the Wash/Dry Selector Timer. The machince works properly when manually rotating the timer, it will not advance on it's own.
    New Friend:
Where can I get a washer /timer 116102529 for a Splendide wd802. I want to avoid replacing the machine since this would be very difficult.Thank you.
Posted on Apr 02, 2011
  • 15,935 Answers
Head over to repairclinic.com and enter your model # for a complete parts list.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
6ya staff
SOURCE:
I put my clothes in wash tub, and rotate the wash timer.
The timer is not advancing. Advance it manually and see if it works. If it does, replace the timer, as it does not engage.
Jan 03, 2016 | Washing Machines
The selector knob on my Whirlpool LER4634JQ1 does not move, so the dryer will not turn off automatically and no "end of cycle" buzzer sounds. Do I simply replace the timer?
Your timer most likely does need to be replaced. The timer has a small motor that causes it to rotate during the cycle and those can go bad causing the timer to not advance. Unfortunately, you cannot get just that timer motor anymore. Hope this helps!
Feb 16, 2015 | Whirlpool Dryers
Whirlpool top load washer won't advance through cycles
A small motor that rotates the timer has gone bad. Common practice is to replace the timer. Usually a mechanical timer of this type is less expensive than a computerized timer.
Mar 14, 2012 | Whirlpool LSB6300PW Top Load Washer
How do I get my ge dishwasher to run? the lights
Hello there and welcome to fixya
If electrical power is available to the dishwasher but the appliance doesn't run, the problem is likely to be a defective door switch, timer, or selector switch. Make sure to turn off the power to the dishwasher before attempting any repairs
To solve a door switch problem, you may be able to adjust the door latch's strike slightly, using a screwdriver
then make sure the door closes securly, if this doesent work
please check the timer as follows
Dishwasher timer concerns can be classified into two general categories: the timer cannot be advanced manually and appears to be stuck or intermittent automatic timer advancement.
1. The timer dial cannot be advanced manually and appears to be stuck. Stuck timers are generally caused by objects that prevent the detergent cup from opening, or by a sticky substance between the timer dial and the control panel.
  • Objects that prevent the detergent cup from opening: If your timer will not advance, open the dishwasher door and check for items that may be blocking the detergent cup.
    Also, check the detergent cup:
    • It should be fully closed at the start of a cycle.
    • It should be fully open at the end of the cycle.
    • Almost fully open between main wash and final rinse.
    If it is in any other position, try to open or close the cup while at the same time rotating the timer. This should free it up. To prevent a reoccurrence, make sure nothing blocks operation of the detergent cup when the dishwasher door is closed and operating.
  • Sticky substances like orange juice that get between the timer knob and the front of the control panel on some models will bond the timer knob to the control panel. If you have this condition, it will be virtually impossible to rotate the timer knob while gently pressing the knob in toward the dishwasher. It will rotate normally if the knob is gently pulled away from the dishwasher while rotating the knob.
    This problem can be solved by gently pulling the knob away from the control panel and cleaning behind the knob with a damp cloth. Do not use excessive force because the knob is attached to the control panel on models affected by this problem. If this operation cannot be performed, service should be contacted to repair the problem.
2. Intermittent automatic timer advancement. This can be described as the timer can be advanced manually, but it does not advance automatically in spots for up to 30 minutes.
  • This is almost always a normal condition and always occurs on models with a "Delay Start" feature.
    Delay start timers increment or advance a couple of degrees once every minute or so during most of the cycle. However, during certain parts of the cycle they increment once every 30 minutes. This gives the dishwasher time to do the job of cleaning your dishes. The long increment times occur during "Delay Start", "Hot Start", "Normal Wash" and "Dry" cycles.
    The timer will not move at all during these delay periods. This is normal operation and service is not needed. If you notice delay times substantially longer than 30 minutes, replace the timer
  • Also ensue that you are getting adequate water pressure and the unit is getting water inside and that the water is at the right temperature 140 is the min. for most units
  • Please check the above and let me know what you have found so i can continue to help there is a lot of things to check but these that i have provided are the most common thing that need to be checked first ok?
  • Best regards Mike
Aug 21, 2011 | GE Dishwashers
My dishwasher has power to it but the heat dry option is lit and it wont start ant idea what to do?
Hello
Do you have any of the extra functions selected, such as "Hi Temp Rinse" etc?
The selector switch has a selection for Hi-Temp Wash; the switch is in parallel with a thermostat mounted on the bottom of the tub and with a contact in the timer. The
selector switch, temp assure thermostat, and the temp boost thermostat are all in series with the timer motor. Both thermostats are normally open thermostats. When
the timer reaches the end of the second wash cycle, the contact in the timer supplying power to run the timer motor will open. At which time, if the selector switch for the Hi-Temp Wash has been selected, power to run the timer motor must come through the thermostats. The temperature of the water in the tub must rise to 137° ±5° F for the thermostat to close and the timer motor to advance. If the water temperature is below 137° ± 5° F, the timer will pause until the heating element raises the temperature of the water in the tub and allow the thermostat to close.
Hi-Temp Rinse
If the selector switch was a selection for a Hi-Temp rinse, the switch is in parallel with a thermostat mounted in the tub, and the contact in the timer, the same as the Hi-Temp wash. The operation for the Hi-Temp rinse will be the same as for the Hi-Temp wash with the exception, on some models, the temperature of the water in the tub will be 150° ± 5° F for the thermostat to close to give a sanitizing rinse.
What do we learn from this? That you either have a bad heater or a bad thermostat. Check the heater for continuity with our OHM meter.
Aug 03, 2011 | Frigidaire Dishwashers
My washer runs non stop on the wash cycle...it washes the clothes but doesn't past the wash cycle...doesn't drain, rinse or spins. What can I do?
Can you manually rotate the timer control to the next steps?
Will it proceed thru the cycles when you rotate the timer manually?
If so, then you can complete the cycle manually for the time being...
If so-- then the clock motor that drives the timer.control is not advancing it.
If yours is a newer machine with all digital controls, then I suspect something wrong in that controller, too-- But I do not have any idea of how to 'advance it manually!
(The blessings of modern controllers!-- Give me the old clock motor driven drum controllers! :-) )
Mack B
Dec 28, 2010 | Washing Machines
Dial does not advance through all parts of the wash cycle
Replace the timer of the unit. With the mothel number that is behind the timer, you can order it. The timer location is at the back of the unit. Remouve the cover at the back of the control panel, then look for the part that look like a smal motor at the back of the knob. remouve the knob and the small screws, then desconect the wires plugs, do not cut any wire. then instal the new one.
Aug 05, 2009 | Frigidaire Affinity ATF6000F Front Load...
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Timer does not advance, even in timed mode
My parts sources list 3 different timers for this dryer depending upon the MAN.#.
They are
33002855
33002808
33002854
Feb 22, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Splendide 2100 Vented Washer-Dryer Logo
748 people viewed this question
Top Splendide Washing Machines Experts
Marvin
Marvin
Ekse
peter gittos
peter gittos
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
