Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
D
David Posted on Apr 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Changed water filter, now no water coming out of dispenser and not making ice making ice
ronnie walters
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jul 25, 2018
ronnie walters
Contributor
Level 1:
Welcome Back:
Problem Solver:
Answers
6
Questions
0
Helped
1349
Points
16
It's possible it was installed improperly.... try removing it and re-installing. May have a filter that is clogged... only way to determine this is to replace it with another new one.
HomeApplianceService
Level 2:
Scholar:
New Friend:
  • Expert 123 Answers
  • Posted on Apr 25, 2015
Expert
Level 2:
Scholar:
New Friend:
Answers
123
Questions
0
Helped
36281
Points
216
1) Both Chill Water & Ice Maker not working means there is a water feeding issue.
1.1 It can be from the House Water Line to Fridge (may be kinked) Disconnect from Fridge and see water coming through house line to a bucket.
1,2 If house line okay... Then the problem on Fridge. It can be Fridge water valve. Fridge Water Filter etc....
1.2.1 When you press your dispensor option for water, due you here a noise of valve activating on the back of the fridge bottom. That is your water valve. If not look into water valve and power getting into the water valve....
1.2.2 If you don't hear a noise from fridge water valve... may be the water filter is not install properly. Fridge water filter has to be installed properly to power up the water valve through dispensor option.
These are few things for you to look into...
If technical, unplug the fridge and then give direct power to water valve (preferably to the fridge water valve related to chill water) so the water should come through dispensor. That way you can eleminate the water filter or water valve, fridge water systems lines etc. So your problem is narrowed to dispensor not communicating with the water valve....
Fred
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on Apr 23, 2015
 Fred
Contributor
Level 1:
New Friend:
Answers
30
Questions
Helped
12208
Points
56
No water in ice maker and water dispenser
Good Morning Friend,
I understand your Frigidaire refrigerator is not making ice and not dispensing water. I suggest starting by changing the water filter in your refrigerator. You should be changing the water filter about every 6-8 months. If this does not work, I also suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try getting water out of the dispenser. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
[LG Refregerator] Model LFX25961AL water does not dispense and ice is not being made
Make sure the wire guide that pulls up when ice is at full capacity is not accidentally pulled up. (this is above the ice bin in the freezer). Pull back down and should make ice.
I have a Kenmore side x side. I have changed the water filter and now water is coming from the water spout when water is needed to make ice. Just prior to changing the filter I noticed water coming from...
Sounds like the dual water inlet valve on the back where the water supply is connected, has gone bad and is leaking across to the other side. It may also put water into the ice maker when you use your dispenser.
2helpful
2answers
The water dispenser is really slow coming out and it takes however to make ice. There is no kink in the water line to the fridge.
water stopped dispersing out of water dispense, No indication as to why. New filter was instlled, checked water line, no leakage indicated, ice maker had been making ice prior to this, turned off ice maker to avoid motor burn out.
3helpful
Ice maker is not making ice
Even though the water dispenser is OK you need to make sure the tray(s) in the ice maker are filling. The filter valve, located to the rear of the ice maker can freeze over and stop water flow. Check the supply line for the ice maker, it may be separate from the water dispenser.
1helpful
Icemaker not making ice
If water is also not com out of dispenser then filter should be changed. If water dispenses but ice ice is not being made, the sensor arm or infrared sensor may be stuck or blocked. If sensor is OK then ice maker needs service.
2helpful
2answers
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
7helpful
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
