Sony 52v4100,had power surge from lightening hitting transformer.the tv when I turn it on green light lites then turns to red 2 binks ,pause 2 blinkd.Tried factory reset, did not help
Sir
PIC OFF/TIMER LED-------Green or Orange LED-------
* Lights up in green when Picture Off is activated
* Lights up in orange when the timer is set
When timer is set, the LED remains lit even
when the TV is turned off
thanks
M Nasir
the number of red light flashes indicate where the fault lies...sony error codes are easy enough to find if you google the model with the number of flashes.hope this helps somewhat as you dont say how many blinks!!
regards,steve.
ps.line output transformer failure rates are quite high on these sets,usually resulting in two red blinks-pause-two red blinks-pause etc...
Hi, Question shows tv is Sony KDF-60WF655. Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen. Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure. Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem. Did you replaced its lamp in last 2-3 years? Thanks.
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
This sounds like a power source problem! (faulty transformer) I would pack it up and take it back for a new one!
This is a problem you can not fix yourself unless your a pro!
Please rate my response!
