I have a different Bosch but changing the door over is straightforward.
1. Remove the plastic cover above the top door which fits over the controls. There are 2 screws under it holding it on. Lever it up from the back on top and it pops off.
2. Remove the hinge for the top door held on by 2 bolts
3. Take the top door off
4. Remove the central hinge between the doors held on by 2 screws
4. Lift the bottom door off
5. Pull off the bottm plastic cover
6. Move the post in the bottom hinge to the other side. It screws out
7 Replace the bottom door
8 Replace the central hinge on the other side (Take off any plastic caps covering the holes)
9. Unscrew the post on the top hinge (there are 2 possible holes left and right) and put it in the other hole.
10. Put the top door on
11. Bolt the top hinge back on the other side
12 Replace top cover and screws.
13 Move handles (unscrew and pull towards the door edge to get them off)
If there is a water/ice dispenser in the door it may not be possible due to routing of the water and electric lines. If the doors can be reversed there should be mounting holes at the top and bottom of the doors opposite where the hinges are now. (They may be closed with plastic plugs that can be pried out.) Checl also how the existing handles are mounted. There should also be holes that correspond to having the handles on the opposite side. (Sometimes they are disguised by a manufacturer's nameplate over them.) If there are such holes then start at the top hinge of the top door. Pry the (plastic) cover off if there is one. Remove the bolts/screws and remove the hinge support. There is a post on it that fits into the hole at the top of the door. Remove the door by lifting it up off the bottom hinge post. Keep track of any washers, etc. that may be there. Unscrew the middle hinge support. Remove the bottom door. Unscrew the bottom hinge support. Remove (and save) any plastic plugs and install the hinge supports and doors in reverse order (bottom to top) on the other side. If there are separate door stops on the bottoms of the doors near the hinges that keep the doors from swinging all the way open, make sure you move them also to the other side. Relocate the handles. Put the plastic plugs, nameplate, etc. in the old holes.
Depending on how long you have been using the refrigerator in its current setup it may take you several days to stop trying to open it in the wrong direction. With model number you could download a manual from the manufacturer's web site. It should have details about reversing the doors. Good luck.
