Washier is about 4 yo. Lately the spin cycle has been getting very noisy, much more than before. Sounds like a bearing going bad?
Highly likely u need a bearing kit
Yes! it is highly likely that the water seal is bad and the bearing assembly is tight and the bearing is devoid of any lubrication making the spinning noisy.
Removing and reset the mechanism with proper lubrication could reduce the noise, but if the bearing is bad then it must replaced.
Hello friend, thank you for your inquiry!
Based off the information you have provided you are hearing a loud screeching noise during the spin cycle on your Electrolux washer. You will hear a certain amount of motor whine during the spin cycle this is a normal operation of your appliance. -Matt
