SOURCE: Olympus FE 150 digital camera shuts on and off repeatedly
There could be a problem with the battery , the charger or the camera itself. I would recommend you send them to an Olympus service center location for evaluation.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $93.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
SOURCE: Camera screen registers color dots and lines only
Googled until I found others with same problem with this particiular camera - then researched the proper address to send the camera to for repair - after calling to make sure they would still repair the camera.
SOURCE: camera has failed to operate giving a "change batteries" message
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
SOURCE: Camera stops working after a few snaps
it acually could be it that was the reason why i had to get a new one!
SOURCE: after charging battery ( and testing with
your very luckily do be using rechargeable 's for 3 years after a year they start going down the drain, your battery tester may be showing that there is power in the batteries but its not enough for your cam,
my advice is to get new ones and you will see.
good luck.
