i saw cople of chips on ebay but many complain there thay are fake. does somone know a bout some real chipsi saw cople of chips on ebay but many complain there thay are fake. does somone know a bout some real chips
You can't post conmments that contain an email address.
Your dts uses drive by wire. The gas pedal is actually an electrical switch connected to the engine computer which then actuate a throttle body motor which causes the car to speed up or slow down. If you mean the car won't acceleration then the throttle actuator is probably going out, this is common and you replace the throttle body assembly as the actuator is sealed onto it. Had the same problem with my 04 srx (which is mechanically the same as a cts). If you have a check engine light on (and you should) get the codes read first as there are a few other problems that can cause throttle problems, however they are less likely the cause.
Yes. The speed sensor in the transmission gives the computer data to control fuel mixture and timing, and it also drives the speedo and odometer. The sensor would need to be tested.
Check your fuses. If you can have your car hooked up to a computer and check the code. The code will tell you where to start. Check your spark plugs and wires. Check for broken vaccum hoses or wires.
Bluetooth compatability is available on Merc vehicles which were originally wired with factory handset (Motorola), iPod adaptor cable & wireless Multi-Handset Interface (MHI). Models from 2007 onwards also had an updated interface.
If your vehicle has the MHI, then it would be a simple case of activating the the MHI device to search for your iphone device.
If you are unsure if you have the MHI adaptor, then contact your local Mercedes Parts Dept. for further advice.
more= my subaru legacy is 2.0 station. 2005
engine 138 hp. not 165 hp
thanks for the tip Rebgagnon
