Apple iPhone 3G Logo
Susan Harrison Posted on Apr 29, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to block a caller?
How to block a texter?
Jesse Allen
Level 3:
Master:
  • Apple Master 307 Answers
  • Posted on Mar 26, 2018
Jesse Allen
Apple Master
Level 3:
Master:
Answers
307
Questions
0
Helped
161079
Points
1872
Settings>Phone>Blocked>Add New to add the number you want to block onto the block list on your iPhone. if you need more detailed instructions, go visit: How to Block Numbers on iPhone and Find Blocked Numbers on iPhone
ka4iup
Level 3:
  • Apple Master 4,062 Answers
  • Posted on Apr 29, 2015
ka4iup
Apple Master
Level 3:
Answers
4062
Questions
0
Helped
1096582
Points
51404
Http://tag.wonderhowto.com/block-calls-iphone/
2answers
How can I block a caller
By using truecaller you can block a caller or go to phone setting to block calls, open the Phone app, select Call History, tap the number, then select Block Contact or Block Caller. To block calls, open the Phone app, select Menu > Settings > Call Reject > Reject Calls From and add numbers. To block calls for numbers that have called you, go to the Phone app and open the Log.
Aug 08, 2018 • Cell Phones
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
BAD PHONE CALLS-SELLERS -AND SCANERS
download blocker from play store the ICON is a padlock you can stop "with held numbers" also you can put in the unwanted caller and texter's by entering their numbers ; all you have to do is follow instructions by the way it is a free app. good luck you will soon have peace and quiet.
Dec 23, 2015 • Cell Phones
Block number from texting me
screen the number of your texter, go to contacts, then choose "block this number"
Jcb tradesman phone only shows numbers on texts not names
I bought one of the JCB Tradesman Toughphones off e-bay and had the same issue.
I notice that newly created contacts work fine. The problem is with about 90% of the contacts that were on the sim card even if I moved them to phone memory. If I open each contact and resave it with a dot or something after the name it works fine and then displays the callers/texters name ok. It's a bit laborious to go through them all one by one but it's a once off chore
2answers
How do i get the phone to show caller id name when a person is calling me i have a jcb sitemaster phone
ive got the same bloody problem... the caller id wont show when someone rings me... how do i get this to work ?
6helpful
LG Xenon Speaking names of callers and texters
its because you need to go to "voice commands", then go to "call alert" & "then press ring only"
1helpful
Block calls from unidentified callers
this would be done if you put a request to your service provider.
2answers
I got Pantech dou costom texh ring tone
umm u cant change them as far as i kno. i have one but u can have a custom ring tone for the caller not texter.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
