We've looked at several manuals and searched the internet and multiple forums to no avail.
SOURCE: setting up voip on nec ipk2 phone systems?
The easiest way is to set up a different extn number range for the sites, then in the system settings in the number scheme you programme the system with the ip address of the distant end against the extensions. Obviously you need a VPN between sites but it works really well as we have a number of installations like this
regards
SOURCE: NEC DTerm 80
Try dialing the numbers 725 and then hang up...to turn it off..same thing. Ours works this way at work.
SOURCE: Lost NEC Manual and unable to tune and connect to antennae -
Able to locate download NEC Manual found via ASK JEEVES
Thanks
Fran
SOURCE: I purchased an LG Bluetooth Model MSB100
Is this a Sony Erickson MSB 100 instead of an LG?
If it is, the code to pair is 0000 (four zeros)
User Guide
http://www.sonyericsson.com/cws/support/accessories/detailed/userguide/mbs-100?cc=gb&lc=en
SOURCE: cannot change time on my Xen IPK Dterm Series i
