Hobart A200 Stand Mixer Logo
k
keith stephenson Posted on May 02, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Parts for hobart l200
Trying to purchase the worn wheel for 50 cycle ac l200 Hobart mixer. Present brass wheel has worn the teeth off. Live in Cook Islands, middle of the pacific ocean. Easiest to get parts form ZN or AU but cant find one with number that can be reached from overseas. Can you help.
Edgar Prado
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 30 Answers
  • Posted on May 05, 2016
Edgar Prado
Contributor
Level 1:
New Friend:
Night Owl:
Answers
30
Questions
0
Helped
10862
Points
92
Check this link
http://thesmartpartsestore.hobartservice.com/
Bill Boyd
Level 3:
Top Expert:
  • Hobart Master 53,816 Answers
  • Posted on May 03, 2015
Bill Boyd
Hobart Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11933763
Points
172802
I typed in hobart service agents in google and got hobartfood.com.au as a site
landline contact phone number is 1800-462-278 and e- mail is [email protected]
2helpful
3answers
Trying to find the age of a Hobart Mixer serial number 1569386
Contact hobart directly, they tend to keep a record of machines, and would probably be able to as sit you
5answers
Hobart A200
hi there,
did you make it sure that all part has been back into place and no small parts has been put away into its place.?
check for any loose screw,
2answers
D-300 number one gear not working
You are going to have to get your hands dirty and open the gearbox. Could be a selector problem or issue with the shaft. If you need parts try Hobart themselves or get in touch with Ann at http://www.MaterialsTestingEquip.com
A-200 hobart mixer grease leak, there is grease present in some of the doughs that we make, black streaks but there is nothing dripping on to the dough...
several reasons
too much grease worn bearings or bushes not holding the shaft in the center
worn out grease seal;
the fix is an overhaul and seal replacement
2answers
Hobart N50 stator assembly replacement
You can go to www.hobartservice.com. select parts and type the machine ML number from the data plate. here are 5 different ML options, otherwise I would have given you the part number.
It will open an exploded view of YOUR machine's build, complete with part numbers.
You can then call your nearest Hobart dealer for a cost and availability. They are still a current model, and for their size, an excellent mixer worth repairing.
Hobart A200 Worm Gear Shredding Brass Gear
no there are no adjustments . you must have bent the case just a little , i dont see any good news for you , sorry . i have worked on hobart mixers for years and you should get 5-10 years out of that gear
3helpful
3answers
More info re: n50 hobart mixer
Judy. Hobart was sold to Illinois Tool Works (ITW) several years ago. The Kitchenaid product line was sold to Whirlpool Corp. several years ago too.
The new N-50 mixers have a motor that is designed by Hobart, but no longer built by Hobart. Last year Hobart began out-sourcing approx. 12-15% of their componnents to Asia. Their parts catalog does not show anything but metal gears. I suspect the new motors have been built in Asia. Wattage is not the output of the motor, but how much power it takes to run the motor and is no indication of how much power goes into your mixing bowl. The true measure of mixing power is horsepower. The N-50 motors are rated at 1/6 HP. Wattage claims by mixer manufacturers is a complete snowjob, and they all do it. Consumers have no protection as a result of this policy. It is a marketing ploy to make you believe that this indicates output power. Shame on all of them! Most componnents of the new N-50's are still manufactured in the USA.
I see that you've done some homework on Kitchenaid Mixers. I wish I had before I bought mine. Yes, they have a plastic transmission housing, and yes, they fail under strong loads demanded by bread dough and stiff cookie dough mixtures (my HD Professional 450 watts failed 5 months out of warranty, after only 30 uses making bread). Go to the www.consumeraffairs.com website and search for Kitchenaid mixer problems and reviews and brace yourself for a shock.
My mixer failed on Oct. 28th. and I had to fight tooth and nail with Kitchenaid to get them to re-imburse me for the cost of the parts that were destroyed by the housing failure. Here we are in 2009 and I'm still waiting for one more part. Kitchenaid parts take at least a month to arrive (in my experience).
I didn't do the research on mixers until mine failed. Since then I've purchased an older Hobart N-50 (with a motor BUILT by Hobart), and this is what I recommend you do, as it will save you much grief down the road. Mine was manufactured in 1990 and only needed. re-greasing to make it like new.
You can find them often on eBay but will have to buy without trying them. Try to find one that is newer rather than older, as a rebuild will get very expensive. I got mine from a Rest. Equip. Wholesaler and was able to try it out in all gears. The previous post (solution) was correct in saying that you should look for one that has a black knob on the shifter handle, this will be a newer one as opposed to an ancient one with an all metal shift lever and potentially worn out innards. If you find one, take it to Hobart, or a Hobart tech can come to you (check service rate) have the unit cleaned, inspected and re-greased. Sit back and take comfort in the fact that these mixers were built like a tank, and will probably outlast you.
Most of all. Good luck, and happy hunting. ricardok45
4answers
HOBART D 300,SERIAL NR. 94.819 808, ML NR.116 12
hi i work for hobart and these part numbers dont sound right.you have to make sure you have the ml number or spec number to get the correct parts.you can call your local hobart branch and they will help you further.
Top Hobart Food Mixers Experts
vince
NOEL
NOEL
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
