My Panasonic Viera 20LA2 was struck by lightning today. I'm crossing my fingers that it'll work after I leave it unplugged for a while, but if not, can I fix it?
You wont be able to fix the TV your self as the power circuit board may have blown - consult a qualified repair man. Buying a surge protector for your expensive electronic goods is highly recommended.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before spend $$ on replacement boards, make sure anything attached to it is powered off. Unplug TV for 5mn to 15min. Plug back in and it should power on. If not leave unplugged overnight before spending on a replacement board. We have to do this 2-3 times per year when someone forgets to turn off auxiliary components (receiver, DVD, cable box, etc) first. It has always come back on.
Yes!!! When going out for extended periods of time unplug TV's from a/c outlet AND dissconnect broadcast signal from TV(cable,sat. etc)
Isolation is the only sure protection against LIGHTNING DAMAGE!!!
I advise purchasing protection from your' service provider.
Two things normally happens after a L storm:1.) One must unplug TV for 5 minutes, then plug back in. 2.) Main glass fuse out, will be near a/c cord. 3.( Power regulator IC may be out. Try these first.
If it was struck by lightning, the surge would completely fry the insides of your TV. Your TV probably won't work anymore and you may have to consider replacing it. Some TVs have accident warranties so something like this could be protected, but if not, you will have to purchase a new one.
