RIM BlackBerry Curve 8520 Smartphone Logo
A
Anonymous Posted on May 05, 2015
My blackberry ID icon dissapeard on my settings list ,hown do i download a new one
RONALD CARTER JR
Level 3:
  • Master 438 Answers
  • Posted on May 05, 2015
RONALD CARTER JR
Master
Level 3:
Answers
438
Questions
0
Helped
91558
Points
1345
Hi I always ask for more details in these situations. The first thing you should do is take the battery out and do a soft reset of the phone. Don't do a hard reset it will erase all your data. I always recommend you go to blackberry.com and see if you can download the blackberry desktop. This will save your information. It can be reloaded back on to your blackberry.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
How to change Blackberry ID?
If you would like to keep your existing BlackBerry ID account and simply change the email address that is associated with the account, use the steps for your specific device below.
Note: Your new username must not already be associated to another BlackBerry ID.
If you need further support, you can get BlackBerry ID support here.
On the BlackBerry 10 smartphone:
  1. Swipe down from the top of the home screen and tap Settings.
  2. Tap BlackBerry ID.
  3. Tap the edit Edit button.
  4. Clear the BlackBerry ID Username field and enter the email address to use as your BlackBerry ID Username.
  5. On all-touch devices, press and hold the space bar to hide the keyboard.
  6. Tap the Submit button.
  7. Read the confirmation message, and tap Continue.
  8. Enter your BlackBerry ID password and tap OK to complete the change.
  9. A message is displayed to confirm the change was successful. Tap OK to return to the BlackBerry ID settings screen.
On the BlackBerry smartphone running BlackBerry 7 to 7.1:
  1. From the home screen, select Options > Device > BlackBerry ID.
  2. Clear the Username field and enter the email address to use as your BlackBerry ID Username.
  3. Press the Menu key and select Save.
  4. Enter your BlackBerry ID password and select OK to complete the change.
  5. A message is displayed to confirm the change was successful.
On the BlackBerry PlayBook tablet:
  1. Swipe down from the top bezel or tap the Settings icon.
  3. Tap the BlackBerry ID Information pencil icon.
  5. Tap Submit.
  6. Enter your BlackBerry ID password when prompted and tap OK.
  7. A message is displayed to confirm the change was successful.
On the Android device, iPhone, iPad, iPod touch, or Windows Phone:
  1. Open BBM.
  2. Tap the More button (3 dots).
  3. Tap Settings. If using a Windows Phone, also tap General.
  4. Tap the BlackBerry ID email address.
  5. Enter the BlackBerry ID Password and tap Sign In.
  6. Tap Edit Account Information.
  7. Clear the BlackBerry ID Username field and enter the email address to use as your BlackBerry ID Username.
  8. Tap Save.
  9. Scroll to the bottom of the Account Information screen and tap the Done button.
  10. Tap the Back button to exit Settings.
From a web browser on any device or computer:
  1. Visit http://www.blackberry.com/blackberryid.
  2. Under Already have a BlackBerry ID?, click Sign in.
  3. Enter your current username and password, and click Sign In.
  4. Next to Details, click Edit.
  5. Clear the Username field and enter the email address to use as your BlackBerry ID Username, then click Save. A confirmation email is sent to the email address.
  6. Open the email from [email protected] with Subject: Confirm your BlackBerry® ID email address. In the message body, click confirm your email address.
  7. On the Confirm your BlackBerry ID screen, enter your BlackBerry ID password and click Submit.
  8. A message is displayed to confirm the change was successful.
How to restore blackberry z10
If you went to Settings, Security and Privacy then Security Wipe. The Balckberry will reload and reboot itself, but you will have to set up the wifi again as you will have wiped out the wifi settings and your Blackberry ID. You need to treat the Balckberry as a new unit and set up both. You can use the ID you set up originally. If you are not the original owner you will need to set up a Blackberry ID.
Blackberry password
How to recover a BlackBerry ID using a BlackBerry smartphone
Something important to keep in mind when recovering a BlackBerry ID password is that you will need to use the BlackBerry Browser on your device or a web browser in order to complete the process. This is a result of a security precaution that prevents the password recovery email from being sent to the device. To recover your BlackBerry ID password, use the BlackBerry smartphone browser or a computer to follow these steps:
1. Navigate to the BlackBerry ID password recovery page
2. Enter the email address that you used to register your BlackBerry ID and fill out the CAPTCHA characters
3. A confirmation page will appear stating "A request to reset your password has been submitted"
4. Open the mailbox for your email address on the computer or by logging into the mailbox\webmail using the BlackBerry Browser and click on the BlackBerry ID password reset email (it can be identified by the sender: [email protected])
Note: Don't forget to check your spam/junk folder in the event that you do not see this email in your inbox.
5. In the body of the email, click the link after the heading "To change your BlackBerry ID password, simply visit"
6. The link will open a new page in your web browser, enter your new BlackBerry ID password in both fields and click Submit
7. You have successfully recovered your BlackBerry ID password!
How to recover a BlackBerry ID using a BlackBerry Playbook tablet
To recover your BlackBerry ID password using a BlackBerry Playbook tablet, follow the steps below. Something to keep in mind is that you may be asked for the answer to the security question that you created during the initial setup of your BlackBerry ID.
1. On your BlackBerry Playbook tablet, open "Options" by taping the gear in the top right corner of the Home Screen
2. From the menu on the left tap "BlackBerry ID"
3. Tap the Pencil icon to the right of "Change Password"
4. Tap "Forgot password?"
5. Enter your password recovery question which you created when the B BID was initially set up and tap "OK"
. Open "Messages" on your BlackBerry Playbook tablet or log into your mailbox/web mail using the BlackBerry Playbook tablet browser and select the email from [email protected]
7. In the body of the email, click the link after the heading "To change your BlackBerry ID password, simply visit"
8. The link will open the web browser on the device, enter the new password in both fields and tap "Submit".
  • That's all there is to it!
2helpful
3answers
I forgot my blackberry ID
On a BlackBerry smartphone running BlackBerry 7 or BlackBerry 7.1:
  1. From the home screen of the BlackBerry smartphone, go to Options > Device > BlackBerry ID
  2. The BlackBerry ID username will be located in the Username field
On a BlackBerry PlayBook tablet:
  1. Navigate to the Options icon.
  2. Select BlackBerry ID.
  3. The BlackBerry ID username will be displayed under BlackBerry ID Information.
Jul 03, 2014 • Cell Phones
2answers
Creat a new blackberry id
    • Do one of the following: When you first set up your new BlackBerry smartphone, click Create a BlackBerry ID. ...
    • Complete the fields on the screen. The mandatory fields include a username (which is an email address), password, screen name, password recovery question, and password recovery answer.
    1. Create a BlackBerry ID using your smartphone - User Guide ...
  • BlackBerry Manuals Help
    Blackberryid reset
    To change the BlackBerry ID password, complete the steps below for the specific device:
    From the BlackBerry 10 smartphone:
    Swipe down from the top bezel on the home screen and select Settings.
    Scroll down and select BlackBerry ID.
    Select Change Password.
    Enter the current password in the Current BlackBerry ID Password field.
    Enter the new password in the New BlackBerry ID Password and Confirm New Password fields.
    Select Submit to complete the password change.
    To confirm the change You have changed your password will be displayed
    My bb messenger and appworld have dissapeard from my phone can you tell me why?
    Sometimes those BB icons end up in a different folder. You may want to check all those folders to see if they're there.
    1helpful
    How to reset if JVM error 102 is hown on the
    Try to replace the firmware / system software of your BlackBerry Boild 9700 to fix your initialization errors. The latest BlackBerry Bold 9700 system software is available through here.
    1helpful
    Blackberry 8310 curve unlocked, lost icons
    As for the Emailing, You must have blackbeery email on the SIM card with the account that you are using. If you are not paying for blackbeery email, then the icon will not appear. As for the other icons, just download the latest firmware update from the O2 (which your phone was locked on) and install it to your computer. Then using the Blackberry desktop, click on the app loader and it will open the list of applications and simply click the ones that you want.
    2answers
    Ebay icon has dissapeard
    go to the start > pogram > in that ebay right clik and send to desktop
    Top RIM Cell Phones Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Kolbrun...
    k24674
    Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
