Question about Mackie Tapco Th15a Thump Active Loudspeaker
On a Mackie Thump Th15a loudspeaker, diodes D106 and D107, which diode has reverse polarity?
  • Stevie Day
    Stevie Day May 09, 2015
    speaker now fixed,both diodes are the same polarity,bought off ebay for £5.68 for 2 diodes posted
  • Stevie Day
    diode type needed are MUR 1620 CTG, Best to order 2 and replace both
    Loyalty:
    Visited the website for 30 consecutive days.
  • 170 Answers
Posted on Jul 15, 2019
    Top Expert:
  • Mackie Master
  • 3,156 Answers
Contact Mackie Customer Service for the best answer. Mackie Tech Support
Posted on May 06, 2015
6ya staff
SOURCE:
My TH-15A starts making VERY loud crackling noises after a few minutes of being turned on. It does not matter if an XLR cable is plugged in or not, and the volume control does not change the volume of the...
buy a canister cold spray and spray on some active components if the noise begins You have a thermical failure in a component on the board can be faltering resistorcircuits or resoldering some active components.
May 08, 2016 | Mackie Tapco Th15a Thump Active...
Hi there, my relatively new Mackie Thump wont power up despite being plugged in / on etc. When I do with it on all i hear is a very low pop sound every 5 to 10 seconds or so
Your best bet is to contact Mackie Tech Support. Here is a link to their Suppot page. Mackie Tech Support
it's likely it needs to go to a repair shop. Here is a link to their service center finder. Mackie Service Center Locater
Feb 05, 2015 | Mackie TH-15A Active DJ Powered THUMP...
No power in Mackie TH-15A
i) I assume the fuse you mentioned was in the mains plug - did you also check the fuse in the TH15A mains input socket? This is accessed by pulling out the tab in the bottom section of the socket (below the centre pin). This is a 3.15Amp antisurge fuse, 20mm type.
ii) If this fuse has blown, then replace it & all may be well ...... but if it blows again, then move to step iii).
iii) With mains disconnected, remove rear panel (outer screws) & check the power supply PCB for damaged components, especially R111 & R112 (100ohms). If the latter are burnt or open circuited, then the amplifier module may have blown.
regards, Dave
Aug 20, 2014 | Mackie TH-15A Active DJ Powered THUMP...
No sound coming out of my mackie
Whether you are experienced in electronics repair?
if not, try this simply way:
1: Test whether the power amplifier is still working. See figure 1.
Power OFF,adjust the EQ settings as shown in the picture.
Minimize LEVEL.Switch ON Power. Touch pin 3 at the INPUT socket by using a small screwdriver or piece of wire / cable.
Slowly raise the LEVEL,a little bit only (as the clock showed 7-8) until
sound is heard in speaker. If not heard, slowly raise again LEVEL.
If audio input signal is heard,it can simply be taken to mean
that the amplifier is working.
If LEVEL at 9 o'clock position,and the audio is not heard,
the possibility of the amplifier is damaged.
Switch OFF the power. Take it to a repair place.
2: When the Power LED is lit, but no sound,
There are many possible causes, one of which is:
I have been getting 3 times similar cases, and all are caused by
two Rectifier-Diode (either or both.) damage on the power-supply-unit.
Remove/desolder,measure, if damaged replace it with a new one.
See figure 2-3.
Hope it helps. Regards.
May 13, 2014 | Mackie TH-15A Active DJ Powered THUMP...
How to replacea bass driver in mackie thump 15a
"How to replace bass driver in mackie thump 15a".
Did you mean,disassembly the speaker enclosure?
Just remove the 16 screws at the rear cabinet, using a screwdriver.
Then remove the 4 screws that secure the speaker, using the hex key. Is the bass driver blown up / broke?
Jan 28, 2014 | Mackie TH-15A Active DJ Powered THUMP...
Power supply circuit diagram
There is almost certainly a reason the PSU has blown, these are not very reliable units and the amp has probably gone and taken the PSU with it. You are better off taking it to a dealer and getting it fixed. If there is no power on the seecondary and there is no short the transformer must have blown (assuming you're not trying to check with a DC meter)
Jan 19, 2014 | Mackie Srm450v2 Srm450 Srm 450 V2 Active...
I had Mackie th15a 110vac and it had busted fuse, when i replace it when a new one it got busted again...i plug the power cable to 110vac without a regulator. what would be the problem in the power...
Almost certainly the amp has failed, as per usual with these, you need to take it to the repair shop and see if it's worth fixing it then sell it once working or for spares if not. Sadly whilst Mackie make some really good kit their powered speakers are not amongst the most reliable
Dec 26, 2013 | Mackie TH-15A Active DJ Powered THUMP...
Bought a used Mackie TH-15A. When powered up there is no sound...at all.
The internal amp is in need of repair. Are there any other symptoms or signs?
Feb 08, 2011 | Mackie TH-15A Active DJ Powered THUMP...
Sir, while ago i sent a message to you regarding my 1202-vlz3 mixer (mackie) i to know how much the secondary voltage supply ?? thanks and god bless
The schematics don't show this, however reverse engineering this there are two windings... one is for the phantom power of 48 VDC... this winding needs to provide about 55 to 60 volts DC to the 48 volt regulator. EXPECT around 40 to 50 volts AC on this winding to the full wave bridge of D1,2,3,8.
The +/- 16 volt power regulated by LM317 and LM337 regulators will likely require about 20 volts DC into the regulators. It will be less than 25 volts because there is a 25 volt cap filtering.
Given a 20 volt DC from the diodes D5,6 and diodes D4,7 the transformer will be around 15 VAC either side of the centertap.
A minimum would be 12.5 VAC and say 18 VAC either side of center.
You should see near pure DC across C1 and C2 with only a little ripple of 2 volts MAX. The ripple should be 120 Hz. An oscilloscope is your friend in this area !!!
Jun 16, 2010 | Mackie 1202vlz3 12 Channel Mixer
Mackie Tapco Th15a Thump Active Loudspeaker Logo
676 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
 Grubhead
Grubhead
Joaquim Martins
Are you a Mackie Music Expert? Answer questions, earn points and help others
