I just replaced the TCON board on my lcd tv because I had audio but no picture and that was what I found in researching online. The set worked great for about 3 days and now I have no picture and no sound. What else could it be. The set powers up and backlight is on but the Westinghouse logo does not appear nor anything else. Model # is DWM55F1Y1
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
SOURCE: No picture on a Westinghouse lcd tv model ltv-20v4
I had this problem with these tv`s. The problem actually lies with the power supply inside the unit. Some of the units i`ve seen have 2 blown capacitors on the power supply (C7 and C6) replacing these works. On others, the capacitors as well as a few transistors (Q8 - Q1) are blown. But on all the sets i have seen with this problem, changing the above components restores full functionality to the system.
SOURCE: Westinghouse LCD tv LTV-32W4 has great sound but no picture.
Your television actually has a backlight bulb which can be replaced at our parts request email and phone number. Email address: [email protected]. (866) 839-5888
SOURCE: LVM-37w1 Westinghouse lcd has picture for 3seconds
Hello, I can assure you it is the inverter board on this unit. The T-CON board (controller) will only mess with your picture in different ways but you the way you describe the symptoms it is for sure your inverter board. The harders part wil be to find some, you should probably look in www.shopjimmy.com, or www.invertercentral.com.
SOURCE: I have a Westinghouse 42
Hello, this is an interesting one since on this unit what ever the device you are using will determin the type of audio you output on the speakers. I would love to troubleshoot a bit more with you live, can you please send me an email of how to get in contact with you to [email protected].
