Question about HP Office Equipment & Supplies
HP Office Jet 4630 E-All in One. Installing to print from 2 computers via wireless network. Wont print from 2nd computer.
Installed on inital computer, running Win 8.1 64 bit HP. Unit printed successfully, with no issue. Installed on seconday laptop, Dell Studio Vist 32 bit. Unit sees the printer and recognizes it, but when attempting to print, it says Cannot Start Printer. Unit has good wireless signal all the way around.
    New Friend:
  • 34 Answers
It's some kind of communication error. I would suggest uninstalling the printer from the second computer. Also, make sure you go to the website for that printer and download the latest driver that was designed for Vista 32bit. If you are using the included software disc it may not have the latest driver updated that fixes this problem.
Posted on May 12, 2015
6ya staff
SOURCE:
adonscott
Guardson Nunez
  • 106 Answers
SOURCE: Cannot print with wirelessly networked printer
hi,
if printing from 2 other computer works fine, will i think its not an issue of IP address which changes somehow. but anyways, try to check if you still have other printer drivers under "PRINTERS" (see control panel). it should say HP Photosmart c6100 series. If you also have there a printer icon that says HP Photosmart c6100 series Copy1, try using it (right click on that icon and choose Set as Default Printer). If you only have HP Photosmart c6100 series under PRINTERS, try to right click, then choose properties. When Properties box is open, click on PORTS tab. then click on configure ports below. Try to type in the IP address of the printer under "Printer Name or Host name or IP address". make sure that you already printed network configuration page to get the exact ip address of the printer, Dont know how to print? do this.
PRINTING NETWORK CONFIGURATION PAGE
1. press setup, then scroll down and look for Network.
2. press okay on network, it will give you the first option "VIew network settings".
3. press okay on it, and it will give you the first option "Print network configuration page."
4. choose that and press okay. it will print the network config page. from this document, you will be able to see the IP address of the printer.
Please let me know if the issue is still not resolve so that i can go ahead and give you another possible solution.
Thank you so much.
adonscott
Posted on Jul 07, 2008
Anonymous
SOURCE: HP Photosmart 2710 is not recognized over wireless connection
light it on fire
Posted on Dec 08, 2008
mbase213
Mark Taylor
  • 728 Answers
SOURCE: how to hook up this printer wireless to my main computer
Hi jjank740;
First off, did you try to recycle your printer? Turn it off and back on again. Sometimes power outages can disconnect that printer. If that doesn't work. Go to the printer and access the system network configuration on the led panel. Type in the WEP number and password again, and let it search for the connection. That should do it. Once it's connected you'll see the blue wireless indicator turn on.
Good Luck
Mark
Please don't forget to leave a rating.
Posted on Feb 19, 2009
Anonymous
  • 16 Answers
SOURCE: printer status says offline, and we can not print on laptop
Hi!
If you're offline with the printer, you definitely won't be able to print.
I'm assuming you're using Windows XP here. Most Windows products will be similar...
On the laptop, click on the Start button, then Settings, then Printers and Faxes. Find your printer in the list, right-click on it and click "Use Online" or uncheck the "Offline" box.
Good luck! Remember to rate the solutions!
Posted on Aug 10, 2009
Dell windows 7 pro 32 bit windows dvd maker says video card
The drivers may now be default Windows instead of original, so you could try forcing by right clicking the setup and using trouble shooting mode. Or just go to Dell support and enter service tag on their web site, then look for updated Win 7 drivers. gl
Jan 25, 2013 | Dell Latitude E6410 Notebook
I installed the printer and share it. It is only available to user who are on x64bit. user with 32 bit win xp cant access it and install/share it. I have tried to download and install x86 driver but...
This is the HP solution for the problem
HP LaserJet, Color LaserJet and LaserJet MFP Products - Print driver Client / Server Connections in a mixed 32-bit and 64-bit environment ISSUE: 32-bit clients are not able to connect to shared Universal Print drivers or discrete drivers on a 64-bit print server or vice-versa. These scenarios may involve Server 2003/Server 2008 64-bit print servers with Windows XP, Vista, 7 32-bit clients. It is also possible that the server editions could be 32-bit versions with 64-bit clients. SOLUTION:
  1. The administrator will need to download the 64-bit AND 32-bt version of the print driver from www.hp.com . If the server involved is a 64-bit version, the 64-bit version of the print driver will need to be installed and mapped to the printer via TCP/IP. Ensure that the print driver has been shared on the network by going to the print driver properties and enabling Share this printer within the Sharing tab. c02030528.gif
    Ensure that communication has been established and that a driver test page can be printed from the 64-bit server. Once functionality has been confirmed from the 64-bit server, proceed to the next step.
  2. Currently, 64-bit clients will be able to connect to the shared 64-bit print driver that has been installed on the 64-bit server as the architecture currently matches. However, if 32-bit clients wish to map to the shared 64-bit print driver on the 64-bit server, the 32-bit version of the same driver will need to be installed within the current 64-bit driver.
    This process can be done by navigating to the printer properties of the 64-bit driver on the 64-bit server, clicking the Sharing tab and clicking the Additional Drivers button. c02030529.gif
  3. Once the administrator clicks on the Additional Drivers button, the next screen will allow the administrator to load the 32-bit drivers by placing a checkmark in the x86 button and clicking the OK button. c02030530.gif
  4. Once the administrator clicks the OK button, a print driver window will pop-up asking for the 32-bit driver components. Again, the administrator will need to download, and extract the 32-bit version of the print driver on the 64-bit server. Once the window below comes up, the administrator will need to navigate to the 32-bit driver components and select the appropriate driver .inf file.
    For example, the UPD .inf file would be the first file in the list and be named hpcuXXXc.inf. c02030531.gif
    Once the appropriate .inf file is selected, the 32-bit driver components will be installed within the 64-bit driver on the 64-bit server. This can be verified as both x86 (32-Bit) and x64 (64-Bit) boxes will now be checked and show the status as installed by clicking the Additional Drivers button compared to the screenshot in Step 3 above.
  5. Now that 64-Bit and 32-Bit drivers have been loaded onto the 64-Bit server, 32-Bit and 64-Bit clients can now navigate to the shared print driver on the 64-Bit server, by manually navigating to the shared print driver on the 64-Bit server from the client machine. Typically the path is \\servername\sharedprintername.
  6. Once the client maps to the shared print driver, printing should work successfully.
    For problems or errors that continue to occur after completing the aforementioned process, ensure that the latest version of the print drivers are being used www.hp.com . If there are problems with older discrete drivers, it is recommended to use the latest version of the Universal Print Driver which can be found at www.hp.com/go/upd .
Mar 17, 2011 | HP Laserjet P4515x Printer
Productivity studio wants Msofts .NET Framework version 2 - The download says not good for 64bit PC - what is correct substitute? Running Win 7 on Dell Inspiron, reinstall following last PC death.
I suggest you install the Lexmark software using the driver from the Lexmark website. First, check if your Windows 7 is running on 32-bit or 64-bit operating system by going the Start menu > right click on Computer > Properties. Then, download the driver using this link: http://bit.ly/dmlCyX (for 32-bit) or this link: http://bit.ly/9drb4y (for 64-bit). Execute the file and follow the instructions on the software. Thanks.
Aug 20, 2010 | Lexmark X4650 InkJet Printer
Laptop running XP desires to connect to desktop running windows 7-driver needed for HP 2840 color laserjet before connection to windows 7 desktop-is driver put on laptop or desktop
There is no driver for win 7, although if you are running on windows 7 32bit there is a work around. Download the software for windows vista 32 bit for the 2840.
Jul 13, 2010 | HP LaserJet 2840 All-In-One Printer
Where to get a driver for dell adamo 13 keyboard? O.S. win 7 32 bits, help
dell.com then go to driver downloads and give your service tag, it should take you right to it
Jul 04, 2010 | Dell Studio 1737 Laptop
Hi... few months ago i installed window7 ultimate on my dell studio 1535. today whn i opened my laptop it gives the following msg Bootmgr is missing i tried to put Vist Cd in my laptop but nothing happened
cehck if hard disc is detected in bios - if yes, boot your comp using the win7 disc. then select your language, then click on repir your computer, just follow on screen instruction until you have recovery tools. select start up repair
Feb 19, 2010 | Dell Studio 1535 Notebook
32bit vista to 64bit win7
your recovery manager files should be on drive D or other partition. if not then its gone. but the operating system cd that goes with your laptop is still better than the factory default anyway but the thing is, youll need the cd everytime you want to reformat.
if i where you, il go for 32bit win 7 since your computer used to be a 32 bit vista. no worries about making the most out of your computer since win 7 eats less than vista anyway. and go for 32 bit since your laptop is made for 32 bit.
Dec 30, 2009 | HP Pavilion TX2510US Notebook
Installation of e-studio 350
U need to confirm the driver support Vista 64bit.
U can obtain the driver at:
http://www.copiers.toshiba.com/support/controllers/ebridge350-450.shtml
Jan 19, 2009 | Toshiba e-Studio 350 Copier
65 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
