When the tv turns on the setup menu is on the screen. If you exit the menu it returns and wont clear
Press CLEAR. The on-screen displays are cleared from the screen and you
return to TV viewing
Ok
The TV can be set up so that it can only be operated with
the remote control.
This feature can be used to prevent unauthorized viewing.
This TV is programmed to remember which option it was
last set to even if you turn the TV off.
Press the MENU button on the remote
control, then use the UP/DOWN arrow
button to select the Special menu.
Press the RIGHT arrow button to activate
the Special menu.
Use the UP/DOWN arrow button to
choose Key lock, then press the RIGHT
arrow button.
Use the UP/DOWN arrow button to select
On or Off.
Press EXIT button to save and return to
TV viewing or press the MENU button to
save and return to the previous menu.
the remote control.
Language
Main Source
PIP Source
Captions
Caption/Text
ARC
Key lock G
Auto Convergence
Auto Move
F Back Next G
SETUP
VIIDEO
AUDIIO
TIIME
LOCK
SPECIIAL
On
Off
With the KEY LOCK ON, the display
'KEY LOCK' appears on the screen if
any button on the front panel is
pressed while viewing the TV.
which option it was last set to
even if you turn the TV off. good luck
regards
shaun
Setup
The Setup menu allows you to access the GUIDE Plus+ system setup information. To access the
Setup option:
1. If the GUIDE Plus+ system isn't on your screen, press GUIDE on your remote control.
2. Press MENU to select the Menu Bar.
3. Use the right arrow to highlight the Setup menu selection.
4. Use the up and down arrows to select Change system settings, Review options, or
View demo.
• Change system settings Confirms the settings you completed in the GUIDE Plus+
system setup are correct.
• Review options Displays the GUIDE Plus+ system auto display options.
On Automatically displays the GUIDE Plus+ system when you press the ON•OFF
button on the remote control.
Off Disables the GUIDE Plus+ system from being displayed when you press the
ON•OFF button on the remote control.
• View demo Runs the GUIDE Plus+ system demonstration
Note: If you have not completed your GUIDE Plus+ system setup, these options will not be available. A
screen will prompt you to complete your setup.
Getting In & Out of the GUIDE Plus+ System
To enter the GUIDE Plus+ system:
• Press GUIDE on the remote.
• Press and hold MENU for 2 seconds on the front panel.
To exit the GUIDE Plus+ system:
• Highlight a program and press OK to exit the GUIDE Plus+ system and tune
to the channel.
• Press GUIDE to exit the GUIDE Plus+ system and tune to the channel
displayed in the video window.
• Press CLEAR to exit the GUIDE Plus+ system and return to the original
channel
OK.
