Heating & Cooling Logo
Emma Posted on May 10, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Teco Inverter split system has error code E1. We cleaned the filter but still wont work. Restarted power to house and it works but not for long, error code comes back up. I cant find my user manual.
Karl Whisenand
Level 3:
Genius:
  • Master 1,554 Answers
  • Posted on May 10, 2015
Karl Whisenand
Master
Level 3:
Genius:
Answers
1554
Questions
Helped
752900
Points
4266
Https://www.tecowestinghouse.com/Manuals/ev_operating_manual.pdf
4 Related Answers
Anonymous
  • 143 Answers
  • Posted on Jul 25, 2008
SOURCE: AIR CONDITIONER MODEL #AF-S85FX--CODE E1
The Sharp e1 problem is a timer that is pretending to demand that you clean the filter. It stops the machine every 720 hours and forces you to do a procedure to get it to go away.
There are 2 possible procedures.
1) Unplug the machine. Hold down the power button while you plug the machine in and wait for a beep about 5 seconds long. Let go of the power button. Unplug the machine. Plug it back in.
2) Unplug the machine. Hold down the mode button while plugging the machine back in and waiting for a beep of about 3 seconds duration. Let go of the mode button. The machine will start. Turn the machine off by pressing the power button. Resume trying to use the machine normally.
If these don't work, the "demand to clean filter" timer is broken and you will need to buy parts to repair the machine.
(Don't you just love having a computer chip in every appliance?)
Anonymous
  • 400 Answers
  • Posted on Mar 04, 2009
SOURCE: LG Inverter Air Conditioner showing CH 02 what can I do?
The model number would be on the right hand side of the outdoor unit and same on the indoor unit if it is a midwall split. If it is a flat cassette cieling type you may need to open the grill, which is simply two little levers either side of the grill, and the grill will swing open. Without the model number it is difficult to give accurate info. However, I can offer the following. One, check the condensate drain. You can just blow into the drain pipe from the outside and this sometimes clears clogged mud in the drainpan. Or two, error reading can also come from phase failure (in the case of a three phase unit) or power related problem. This can be solved by switching off the mains and then switching on again to reset. If you have a phase failure you would need an electrician to confirm that the power supply is good. Unless you have a volt meter.
Anonymous
  • 51 Answers
  • Posted on Apr 13, 2010
SOURCE: yonan ac split mini 1.5 ton error codes E1
CHECK ROLLOUT SWITCH AND CHECK FOR A POSSIBLE
GROUND FAULT..OR FUSE..
hvac1960
R Subramaniyam Iyer
  • 2133 Answers
  • Posted on Dec 06, 2010
SOURCE: First time I've tried using the cooling on my
E-1 error means coil sensor (cooling) defective. Replace it.
Testimonial: "Thanks heaps. I'll get back to the retailer for parts under warranty. Too far out of town for labour warranty but knowing the problem helps. thanks"
Comfort Aire mini split E1 code 2 weeks after installation
NOTIFY COMFORT AIRE WE ARE NO PART OF THAT COMPANY
WHAT IS FAULT CODE 00 01 Ad on Teco LU160DHRA1 Air Con
Carrier Split Air Conditioner Error Codes - AC Error Code
acerrorcode.com/carrier-split-air-conditioner-error-codes.html
Jan 25, 2015 - REMOTE CONTROLLER FOR AIR CONDITIONER (SPLIT TYPE). Carrier Split Air Conditioner Error Codes. 00-01-02-03. 11-12-04-05.
What is tgm inverter error code e1
Robert Moller have the answer. Thnx Mr. Moller.
Display Codes:
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
What to do to fix the E1 error on a haier her08xc7
Push buttons about five times each beforjust to make sure they are not stuck....then......Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset. Clean the filter. See the Care and Cleaning section in your use and care manual. After cleaning, replace the filter and plug the air conditioner back in.
Other forums say the E1 code is because the AC thinks a button is stuck or because it's dirty, but almost all of them say to use the remote and it'll work ok.
14helpful
3answers
Error code on air conditioner e1
Search for this problem on web or contact Sharp Technical Support for the following procedure:
1. Unplug unit.
2. Hold down power button while plugging in unit. It will do a short self-test and then beep. leaving unit off.
3. Release power button and unplug.
4. Plug in again and turn on normally. This should last for about 720 hours, at which point the E1 error will come back and you need to follow the procedure again. (You might as well clean the air filter at this point just in case it really needed it...)
Top Inverter Heating & Cooling Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you an Inverter Heating and Cooling Expert? Answer questions, earn points and help others
