I can't get my Sennheiser wireless headphones to work on my TV and can only use them plugged into the Freeview decoder. The audio and visual don't quite synchronise plus I can't watch DVD's.
I hope this may help you.. https://www.youtube.com/watch?v=jWx6rX434CM visual is always my best teacher.. if not then refer to the manual http://cdn.vizio.com/documents/downloads/hdtv/M320VT/615M320VT%20User%20Manual.pdf
You should be able to hook the tv to the cable box the cable box should have your A/V jacks. If so unplug the PS3 plug in your receiver to the cable box and run the PS3 through the receiver. Also check the side of the tv for HDMI inputs if you have HMDI you can go to Radio Shack and get a converter to go from HDMI into A/V
Ok.. first.. the simple thing is to go into your television menu and turn the television speaker OFF.
Then exit the menu and turn the volume up.. try your headphones now.
Next.. check the back of the TV for a FIXED AUDIO OUT.. plut your headphones into these outputs.. if you have these.. you can simply turn the set down.. and use the volume control on the headphones.
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections..your current “work around” is your only solution.
