Hello Graham;
My name is Peter. I am a retired field service refrigeration technician.
Some freezers have pre-marked holes for reversing the door. Inspect the opposite side of where your door hinges are. Also inspect the opposite side of where your door handle is to see if there are pre-marked holes.
The trick of reversing the door is the door alignment. Have someone hold up one side while you tighten the door hinges. You may have to loosen the hinges and repeat this process to get good alignment.
If there are no pre-existing holes you may try to drill them your self, but you must be exact in the location of the holes. Make sure you can move the door handle.
If your temperature control is on the door do not attempt this, the wiring harness is too short.
