Sony BRAVIA  KDL-40XBR2 40 in. LCD HDTV Logo
P
Patty Moore Posted on May 14, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv power cuts on power light lit no picture then Tv turns it self off, when picture appears there's waves in picture and tv turns itself back off and on with no picture just black scree
Mike M
Level 3:
  • Sony Master 3,349 Answers
  • Posted on May 14, 2015
 Mike M
Sony Master
Level 3:
Answers
3349
Questions
0
Helped
686183
Points
16707
Hi Patty
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Samsung Tv UN46F6350AFXZA Pwr on, Logo appears, Smart boxes dispays 5-secs, then go black, Red lit go off, but back lit on for 21-secs. then back lit turns off & Red light turns on. Ready...
Cable connection problem: Your Samsung Smart TV is likely to have a black screen issue due to the cable connection problem. Loose connections, damaged cables or inactive power sources are the probable cause of the problem on your TV. ... If the menu appears on the screen of your TV, then the problem is with the sources.
Sanyo dp50747
sounds like a mainboard problem
5helpful
Last night watching tv, picture cut off (black screen) but power light on set stay on. then after bout 30 seconds the power button went off. Turn set back on , powere light lit but no picture and again...
Power supply board is dying not giving the tv correct voltage anymore.The power supply board,that the board power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
4helpful
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
1helpful
No picture but has sound
The problem can be caused by a bad sustain board (Ysus Zsus) , the popping sound is often caused by a capacitor blowing up.
The TV must be taken apart and tested before eventually replacing sustain boards.
1helpful
6answers
My LG TV
switch on no picture but short period of sound then nothing
2helpful
2answers
have a 42 inch rca 42PA30RQ NO PICTURE OR SOUND WHAT CAN I DO MY SELF BEFORE SPENDING A LOT OF MONEY TAKING TO A REPAIR SHOP
1helpful
4answers
hello .this does sound like bad solder joints .all printed circuit boards do this after a while due to heating and cooling .is not advisable to try to repair yourself .possible electric shock and spiking .will do a lot of damage .take to a shop to have repaired
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
