Try resetting the tablet if no reset button do a factory reset power off then at same time hold the volume up button and power button when it turns on it should take you to reset options use vol up and down to move to factory reset and use power button to confirm.
If volume up and power doesn't work use volume down button and power at same time.
It could be two things, Jack: I would start by plugging it in to your charger for about 24 hrs to make sure it's not just the battery after that length of time not being used...OR, you might have to reset it to factory settings.
In the case of password lockouts or freezing, doing a hard reset on your android device could help you get back to the factory defaults.
First you need to make sure your tablet is powered off.
Hold down on the Volume + button and hold down the Power button at the same time.
As soon as the tablet's screen turns on, let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen.
At this point you will see a screen with boot options.
Use the Volume - button to go down to Wipe Data Factory Reset and tap the Power button to select this option.
On the next screen use the Volume - button again to go down to Yes and use the Power button to select.
At this point it will be going through the wiping and resetting process.
When it's done you will see the first screen you came to when you first started the setup.
Just tap the Power button to select Reboot System Now.
I Forgot My Password To Unlock To My Tablet?
Factory Data Reset - Factory Data Reset can be accessed through your Settings which can be found either on your main screen or in your Apps/Widgets (tap on 6 squares in upper right hand corner) menu. From Settings, on the left hand column, tap on Backup and Reset. On the right hand side tap on Factory Data Reset. This will take you to a screen that will give you the option to check the Erase SD Card option which, when checked, will ensure that your pictures and any other personal information on this device will delete during the reset. Last, tap on Reset Tablet and Erase Everything.
Tap on Settings.
Tap on Backup and Reset on the left hand column.
Tap on Factory Data Reset on right hand side.
Tap on Erase SD Card. (optional)
Tap on Reset Tablet and Erase Everything.
Or
Hard Reset G2 - In the case of password lockouts or freezing, doing a hard reset on your android device could help you get back to the factory defaults. First you need to make sure your tablet is powered off. Hold down on the Volume + button and hold down the Power button at the same time. As soon as the tablet's screen turns on let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen. At this point you will see a screen with boot options. Use the Volume - button to go down to Wipe Data Factory Reset and tap the Power button to select this option. On the next screen use the Volume - button again to go down to Yes and use the Power button to select. At this point it will be going through the wiping and resetting process. When it's done you will see the first screen you came to when you first started the setup. Just tap the Power button to select Reboot System Now.
Make sure tablet is powered off.
Hold down Volume + button and Power button at same time.
When screen comes on let go of Power button.
When the large Android shows on screen let go of Volume + button.
Use Volume - button to scroll to Wipe Data/ Factory Reset
Many people say to push and hold down the Volume(+) and Power button at the same time. Push and hold for as long as twenty seconds until you see a green android with green text.
But, on some devices and some Android O/S versions it takes pushing and holding the Volume(-) and Power button and holding them both down for twenty seconds or so or until you see the green Android and text screen. This will show the Wipe Data/Factory reset option. Select this option by scrolling using the Volume(+) button and engage using the power button. Some devices give you a second screen with a list of *no no no no no* and one line of Factory Reset. Again, scroll to the Reset option using the Volume(+) option and select it using the power button.
If the above doesn't work, either your battery is dead or your device is dead.
1.hold down the power key for 10 seconds to turn off the unit with nothing hooked to the unit (no ac/no usb/nothing)
2. hold the volume up key (+) and the power, once the screen starts to turn on release the keys.
3. NEXT you should get a robot laying down with a red triangle, push the power key one time. This will get you to the menu screen.
4. from here you chose the reset factory by using the volume down (-). Once you have that line highlighted press the power button.
5. next use the (-) key to get to yes to reset/reboot followed by the power key to chose the option.
6. tablet will come back on and be just like you got it from the store originally.
Since I don't know which exact Proscan Tablet you have, here is how to restore the PLT9045K.
1) Make sure the tablet is powered down.
2) Press and hold VOLUME UP(+) and DOWN(-) buttons, plus POWER button all at the same time.
3) Insert a metal pin in the RESET hole at the back of the tablet, then push and hold it for 2 seconds, while still holding the VOLUME and POWER buttons. Make sure the pin is pushed. It seems like nothing happened, but just keep on going to the next step.
4) Power ON the tablet and immediately, PRESS and RELEASE continuously the VOLUME UP(+) button in order to get the display as showing dead tablet (dead robot).
5) This is the critical part. Make sure you do the right sequence or you will start again from the beginning. Press and hold the POWER button, then press and release VOLUME UP(+), and the display will give you a screen showing different options.
6) Choose the option wipe data/factory reset, by clicking POWER button to scroll down. To execute the selected option, press VOLUME UP(+) button. The tablet will reboot back to its factory setting.
1) Make sure the tablet is powered down. 2) Press and hold VOLUME UP(+) and DOWN(-) buttons, plus POWER button all at the same time. 3) Insert a metal pin in the RESET hole at the back of the tablet, then push and hold it for 2 seconds, while still holding the VOLUME and POWER buttons. Make sure the pin is pushed. It seems like nothing happened, but just keep on going to the next step. 4) Power ON the tablet and immediately, PRESS and RELEASE continuously the VOLUME UP(+) button in order to get the display as showing dead tablet (dead robot). 5) This is the critical part. Make sure you do the right sequence or you will start again from the beginning. Press and hold the POWER button, then press and release VOLUME UP(+), and the display will give you a screen showing different options. 6) Choose the option wipe data/factory reset, by clicking POWER button to scroll down. To execute the selected option, press VOLUME UP(+) button. The tablet will reboot back to its factory setting.
You'll need to do a factory reset: 1.
With the device off, press and hold Volume
Up and Power.
2.
Release the Power button when you see the logo, but continue
to hold Volume Up until the recovery screen appears.
3. Use
the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4.
Press Volume Up continue.
This will reset you device to factory settings, however
anything on your SD card will still remain.
At this point you will need to start fresh as if you just
bought the device -- register with your email address, etc.
