Question about Behringer Music
My behringer 4000 watt amp turns on and only has a red light instead of blue and no sound
    Top Expert:
  • Behringer Master
  • 3,156 Answers
You need to take it to the repair shop.
Posted on May 17, 2015
6ya staff
SOURCE:
When i plugged it in the lights started flickering and some smoke came out. Now when i plug it in it won't turn on
sounds like you blew some resistors, or perhaps melted something. Take it in to a specialist and get a quote for repairs
Jan 29, 2014 | Behringer Vt100fxh Virtube 100-watt Guitar...
Hi, I have a BEHRINGER V-Tone GMX212, I left it
Did you left the amp on overnight with a guitar hooked up to it?
Oct 29, 2013 | Behringer V Tone GMX212 2X60 Watt Stereo...
Monitors not audible with Behringer 1680S
Assuming you're trying to power the monitors from this unit as well as the mains.....Confirm that the amp switch is in the middle position which splits the internal amps....one for main and one for monitors. Output A would power the monitors.... B would power the mains.
Aug 26, 2012 | Behringer PMP1680S Europower 10-Channel...
I own a Behringer Ultratone K3000fx 300 watt PA/Keyboard Amp that stopped putting sound out. The amp is getting power just not putting out any sound at all. Just wondering if this is an easy fix or I...
This is most LIKELY an electronic problem... possibly in the final power amp. Repair may be a simple failed component or a mass number that fail like a stack of dominos. Take it to a shop for repair.
Apr 16, 2011 | Behringer Ultratone K3000fx 300w Keyboard...
What is the best powered mixer to go with my b215xl 1000watt speakers
The PMP 6000 or 4000 depending on how many channels and effects you need is a good match.
READ THE SPECS... the speakers are capable of 250 Watts RMS (not 1000 as that is PEAK) power... like the ridiculous claims of 4 Hp for shop vacuums that run on 120 volts.
The 4000 and 6000 will generate about 250 Watts per side into 8 ohm speakers so is well matched for the B215XL speakers... by matched we mean the speakers are not likely to get blown out.
Connect a 500 Watt per side amp to the speakers and you will be buying replacements in short order.
ALSO realize how much sound you will get from the speakers.. they will cover a 2000 square foot venue fairly well. I suggest you get a sound level meter so you have a metric of levels when you are using the system. If you need more sound, you can add a second set of the speakers in parallel.
Feb 09, 2011 | Behringer PMP6000 / B215XL Powered Mixer...
Hi,I turned on my Marshall mg series 100 dfx and there is no sound,just static comes on.Its starts with a kinda bad feedback sound than turns to loud static.
I suspect the power supply for the effects processor has failed. The effects unit will "go crazy" when power supply is too low voltage.
If the amp has loud noise, then the power amp portion is PROBABLY OK.
I had a similar problem in a Behringer amp caused by a bad electrolytic filter cap.
Aug 11, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Music Logo
63 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Chickenwatt
Level 1 Expert
Ric Weide
Ric Weide
Level 1 Expert
Are you a Behringer Music Expert? Answer questions, earn points and help others
