Typically when this occurs, it is an indication of a short circuit in the motor controller board. To test to make sure the problem is in the board
1) Unplug the treadmill from the wall.
2) Remove the motor hood.
3) Unplug the speed wires from the board. On many boards, you will have 2 to 3 wires that control speed and many are labeled H, W, and L. If you cannot find the speed wires, do not guess, contact us with your make and model number and we will try to help you with the wiring.
4) Return the treadmill to a usable position once the speed wires are disconnected and plug the treadmill back in.
5) If the treadmill begins to run at full speed, the motor control has failed and requires replacement.
6) If the treadmill does not run at full speed you could have a speed input problem, wiring problem, or another short circuit.
For any further troubleshooting questions please do not hesitate to contact us, our number is 888-713-2880 or check out our Tech Support Center online
http://www.sportsmith.net/supportsearch.aspx
Always hear to help, SportSmith
SOURCE: Pro-Form Sport 1000 treadmill does not stop inclining
Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
SOURCE: how can i adjust speed and time of the treadmill .
Well it's a thirty two page manual so I can't post it here. Here is the link to your Treadmills on line manual: http://www.iconservice.com/pdf/PFTL912051.pdf
SOURCE: pro form 520 treadmill
I know this thread is a little old, but did you get your treadmill working? I have a 550e that does the same thing. The company has sent me 2 controller boards, but still doesn't work.
SOURCE: describe how to unfold a treadmill, pro form ex
Hold the upper end of the treadmill with your right hand on the back end of the unit. Using your left hand, pull the lock knob to the left and hold it. Pivot the treadmill down until the frame is past the pin on the lock knob. Note: You may need to push the handrail to the side slightly. 2. Move in front of the back end and hold the treadmill firmly with both hands, and lower the treadmill to the floor. CAUTION: To decrease the possibility of injury, bend your legs and keep your back straight
SOURCE: got a 390pi proform and when I step on the
Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lifting one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process the other side. If this unit bogs down again then you will have replace the running belt and possibly the deck.
