Question about Hisense Televison & Video
Hisense 55h6sg comes on to logo screen but wont bring up cable channel
When you turn the tv it on it comes up to the hisense logo screenand stis there and will not bring up the tv channel from the cable box. you have to unplug it several times.
    Top Expert:
  • Hisense Master
  • 76,204 Answers
Corrupted software. A firmware update is necessary. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on May 17, 2015
6ya staff
SOURCE:
How can i get the channel auto scan on my Hisense 55h6sg tv to find any channels.
If it is asking for zip code you have not told it to scan for over the air or antenna channels when it asks air or cable
Dec 12, 2016 | Hisense Televison & Video
My Hisense TV want come on but the red light in front is on and the TV want come on what should I do
It's on.. you need to change what "Mode" it's in..get your manual out.. then get into menu settings.. toggle to Air/ cable/ ect.. plus make sure your on channel 3 or 4 depending what you had it saves on with your cable / sat box
Nov 02, 2016 | Hisense Televison & Video
I HAVE THE HISENSE LOGO COME UP AS USUAL AND SOUND, BUT I GET NO PICTURE!
Hi, Hisense logo and sound coming means your TV is working. Please check the input video source.
May 22, 2015 | Hisense Televison & Video
I have a motorola dcx 3200 cable box and its asking for command code please help
Codes to check with motorola are 035,048,029,085,092. If you wish to get more codes and other details, check this link.
Feb 15, 2013 | Televison & Video
Everything working except I can't get digital channels. It comes up with no signal. But all digital SBS channels are working fine. How could that be.
Is it saying no signal or one moment please? No signal is a dead give away; there isn't any. One moment please can be several things. Low signal or cable box isn't active. How do you have your connection from your cable box set up as? Coaxial cable, RCA, HDMI, or component? Also, make sure whatever connection you're using, connect from you cable box out into your TV's in (type of cable you're using) Make sure you're on the correct input. For example. RCA may be video 1 or 2 depending on where you plugged it in. Hdmi -> may be HDMI 1 or 2. Coaxial may be channel 3 or 4 on your tv set. Hope this helps.
Mar 02, 2011 | Hisense Televison & Video
When i turn on the tv it just shows the Phillips logo and nothing else. the channels don't come on.
Tried tv and cables or satalites boxes unplug,replug it back like about an hour later.The tv will be reset itself back to the factory setting and the those boxes will updated it softwares.The tv should be working again.
Jan 17, 2011 | Philips 42PFL5603D 42 in. LCD HDTV
Can't change TV to CATV mode
You must unplug the cable connecting the television and the cable box. Then turn the television off and then back on. Do not turn the cable box off or disconnect the cable in wire from the cable box especially if you use Cable Vision. It will take up to 20 minutes before the box comes back on. Now turn the television back on. When you access the Channel System menu, you have the access to the submenu choices. Change the Antenna option to CATV and the Current Channel to 3. Reconnect the cable box to the TV.
Also those that are having problems with the TV turning off periodically, make sure the sleep mode option does not have a number in it. For example, if the number is 10, it will turn off every 10 minutes.
Sep 05, 2009 | Memorex MT2206 TV
Trutech dvd-r
Set it for antenna and use the single channel it sends to your TV, which is the only signal coming out of your cable box
Feb 18, 2008 | TruTech T650-DR DVD Recorder
Televison & Video Logo
353 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
