Panasonic VIERA TC-P55VT50 55-Inch Logo
c
cyndy ezell Posted on May 19, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Plasma TV with black screen and 6 red light flashes.
I have a 2012 Panasonic tc-p55vt50 plasma tv. When turned on the red light flashes six times and has a black screen. I removed the back panel and noticed the dual fans turn on for a split second when the tv is turned on and goes back into the flashing code(6 blinks). Then I disconnected the ribbon cable connections at SC20 and C20. Pugged in the power cord and turned on. The red light started flashing 8 blinks with a black screen. I then reconnected the ribbon cables SC20 and C20. I turned the power back on and checked terminals C561 for 5volts and TP for 15volts on the C20 board. I only get voltage for a split second when the tv is turned on and the dual fan come on briefly also. When the code is flashing 6 times I again press the power button for about 3 sec. and the black relay on the power board(Pboard)clicks on and that's when I get a voltage reading for a split second. Then the black relay clicks again and no voltage, black screen and red light flashes 6 times again. When I disconnect the SC board from the power board the red light flashes 7 times. I reconnect the SC board then disconnect the top right board and get 8 flashes from red light. I then reconnect the top right board. when I disconnect the main board from the power board nothing happens at all. Do you have any suggestions or do you know what board needs replaced? Thank you
Level 3:
Top Expert:
  • Panasonic Master 76,851 Answers
  • Posted on May 19, 2015
Panasonic Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14994308
Points
237762
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Testimonial: "I have turned the TV on and off waiting a few seconds in between testing and still get 6 blinks. What would be the next step?"
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
No picture. TV blinks 8 times
I have come across 6 blinks; 7 blink and even 10 blinks.
the video below may throw some light. Not sure if the blink codes are universal across models. Panasonic plasma tv 7 red blinks of *****
TC-P55VT50 plasma. What does 3 blink code on turn on mean?
Did you check for that in the trouble shooting section of tv manual?
It has the codes there.
If no manual you can get it from Panasonic web site.
Why does my Panasonic Viera VT50 have no picture and red led blinks 3 times
First thing, check the HDMI input and make sure it is firmly connected, same for the power cable, obviously. My Samsung goes similarly nuts if it detects no signal from the currently selected input but after 1-2 minutes it eventually stops and I can change the input source.
1helpful
Panasonic TC-P42S30 plasma power light on black screen no sound?
Main digital board should be troubleshooted. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center
Panasonic tc-p60gt30 won't turn on. Something hit screen. Screen did not crack but now won't turn on
May have damaged the PDP (plasma display panel) inside---if the panel which is fragile shorted inside it will trigger shutdown.
2helpful
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
