Question about Freezers
How do I reverse the door from right to left - Freezers
    Sergeant:
  • 331 Answers
Usually srews at top hinge remove and lift door, same with other side, and then reverse doors, handles need to be reverse also
Posted on May 19, 2015
6ya staff
SOURCE:
Can you reverse the door swing on a upright freezer. Frididaire model fffh17f1rwo
Hi Debbie,
I'm sorry, but I don't think so. There is a key that pops out when you lock it so I doubt the door can be reversed.
See page 8 of this manual under Optional Features and reversing the door swing is not listed.
On the positive side, it does have a high consumer satisfaction rate.
Happy 4th! :-)
Jul 05, 2017 | Freezers
Good day! The center flap (vertical hinged flap) no longer rotates back in when closing the left door. Result: the flap remains "out" when closing the door thus banging up against the right door.
Their is a factory issue on some models call the factory to see if your unit is a defective unit. Other wise the door flap has to be replaced. Not cheap..
Oct 30, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Reversing door
some can be many can't use your head and look at the hinges
May 11, 2015 | Freezers
Blizzard lb 1ss upright freezer change door opening
Under the bottom hinge, unbolt it, remove plastic plugs on other side of door, transfer hinges over and door handle, refit the lower one in new position, put plastic plugs in old holes
Mar 12, 2013 | Freezers
I have a kenmore upright freezer model 970-254326 bought in 2011 from sears. The door opens left to right but in my tiny apartment I NEED it to open from right to left just to put things in and get th
You should see some plastic plugs or holes for mounting bolts on the opposite side of the freezer case. The latch mechanism should adapt from one side to another.
You would remove the top hinge and then lift the door off of the bottom hinge. Then you would remove the bottom hinge and switch it to the other side. Place the door onto the bottom hinge and then install the top hinge on the other corner of the case to match.
You should be able to move the handle from one side to the other. The magnets in the doorseal should work as before to keep the door closed. The interior light is usually centered on the bottom to aid in reversing the door opening.
Dec 30, 2011 | Kenmore Freezers
Gladiator Model No. XXRK- Freezer door was left ajar overnight a little while ago - Now I cannot get the temperature back to zero. I cleaned a blanket of dust off condensor coil- no change... Not Always-...
Gladiators are a unique breed from any other style of refrigerator for their convertible capabilities of altering which section you wish to be the fresh food or the freezer, and the ability to use it in colder ambient temperatures than a typical residential refrigerator. This unique capability requires the use of a reversible fan motor and and dampers as well as additional foam insulation. If the door was left open, you have likely a buildup of frost and or ice in these air ducts as a result. My advice, empty it out, unplug it, open BOTH doors, blow a fan into the cabinet for a minimum of 24 hours. The water coming from the suction line of the compressor could be a sign that there is a little too much refrigerant in the system, or that it is in a fairly warm area, or near some source of heat.
Oct 03, 2010 | Gladiator Freezer GAFZ21XXRK
Door swing
yes any door swing can be reversed.take a good look and you will see the screws covered up with plastic covers .the door has to be removed first but check it out and you will see its not a big job get everything ready and it can be done within 10 minutes.adrian,,,,
Jun 29, 2010 | True 19 cu. ft. / 538 liter Commercial...
Coldtech freezer door reversal
http://www.ascendmfg.com/PDFs/CT/hdmanual.pdf
start at this web site and see if this manual will help. It has phone number on last page if you need to call them.
ColdTech is now Jimes Corp. Just Google you unit if what I have does not help enough.
Good luck to you.
Oct 21, 2009 | Coldtech 21 cu. ft. / 595 liter Commercial...
Taking out trays for cleaning
Usually the holes are deeper than they appear in the side walls. Lift the shelves just a hair and then push them left...the right side should now be outside the hole and able to be moved upward until left side clears.
Reverse this process to reinsert. Good Luck.
Aug 21, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Cannot reverse door on Electrolux fridge freezer
Basically they needed to supply an additional door mount for the left hand side of the door as well as the right hand side. Problem now sorted. Poor instructions in the manual didn't help here!
May 26, 2008 | Freezers
Freezers Logo
142 people viewed this question
Top Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
