I think you could get it reset if its linked to your email but i cannot seem to recall how exactly try to pull the top down or something and see if there is an option there
1. Reset to original factory setting by typing *2767*3855#, youre phone will reboot
2. Then insert a sim card that is from another network that your phone is not locked to.
3. An Wrong sim message will come up on the screen
4. When message appears type in* #9998*3323#
5. At this time a white screen will appear which says “exit”
6. Tap the rigth soft key, (occasionally it will not go to the next screen, if so press the down key)
7. From the menu that appears scroll down to the malloc Fail option, this will reboot, and normal service screen will appear.
8. Then type *0141# and press the green call key, Personalized will appear on the screen, and the name of the current sim card provider will appear on the screen.
9. Turn phone off, and then turn on
10. Go to menu by tapping left soft key, then settings in bottom right hand corner, then choose option number 7 security, then choose option number 6 Sim Lock, select option 1 disable
11. Then enter 00000000 (eight zeros), the message will come up sim lock disabled with a check mark, your phone is now unlocked to use with other carriers.
Ifyou forget the HTC Salsa smartphone lock screen pattern, which is more thanfive times, you can open it by entering the Google Account user name andpassword. If you have tried to open up to 5 times and still fail, you arerequired to wait about 30 seconds and then press OK to continue. If the screengoes off, press the power button to restart and then open the screen. PressForget pattern when the button appears. Enter the Google Account name, passwordand sign in, you will be prompted to create a new lock screen pattern
removed your battery. then check it.. go to setting then of the locking ... if appear put locking code.. try to enter. 0000 or 1111 or 1234.. if 5 digit code just add one . like 00000,11111.12345
there is one option in the mobile Sim Lock.. i think your doughter hit Sim Lock option. don't enter the wrong pin code because as you enter the wrong PIN code 5 times Sim will block Sim lock having the same password as your phone password default password is given in the guide book of mobile see it from there & open the sim lock if you don't want the same problem again then go to the settings there is one lock option ... hit on the sim lock ... then off it.. the lock will not appear in future..
Yeah, I recently bought a nokia n97, and already it is freezing. I lock the keypad, and then unlock to try and write a text, nothing. so i lock again and unlock nothing... I do this three or so times before it works:(. My phone was locked when somebody tried to call me, and as the screen was frozen, I could not answer....
HELP ME PLEASE.... I only got the phone about 2 months ago...
This happens around 5 times a day.... There is a chip in the screen, could this be the problem?
thanks
i m not sure if this is gonna help but still u can try reformatting it maybe it will change the code back to 12345 just press answering button,1,3 and * and while keeping these 3 buttons pressed just keep the starting button pressed at the same time.don't leave the buttons until "reformatting" appears on the screen.best of luck
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons
