SOURCE: how to dismantle a sony ericsson w850i so that i can get to the main board inside
hi
here some screen shots , take care when doing this
http://formymobile.co.uk/Dismantle/w850disassembly.htm
riz.
SOURCE: Dell Inspiron 1000 Disassembly
The teardown information from rbrown67 was very accurate and easy to follow. It helped tremendously in tearing down my machine to replace the AC plug.
SOURCE: drill chuck swap
1. Turn the screw clockwise to take it out.
2. Then you needs 3/8 allen key & insert the short side of the allen key & tighten the chuck.
3. hold the drill at the edge of the table & wack the allen key
counter clockwise & do it again as needed.
4. dewalt keyless chuck will fit but you might add a washer to insure the chuck is not rubbing the clutch collar.
5. putting it back together the other way.
SOURCE: Is the carb adjustment screw on bottom
Hello
>>The Following is an Instruction File I made for Correcting this Problem. Any Input is Appreciated.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers.
>>There are Several Location for the Air Mixture Screws.
>>The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is the Nearest to the Engine.
>>The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>The Engine Idle Screw is Usually Easy to Identify because you can See where it Makes Contact with the Carburetor Throttle Shaft Plate Stop Ear. The H and L Air Mixture Screws Go Into the Body of the Carburetor and the Tips Cannot be Seen.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore).
>>If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required.
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns.****
>>Holding the Throttle Full Open, Start the Engine.
>>Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle.
>>Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle.
>>Reset the Engine Idle if Required. If This Carburetor has a Single Air Adjustment.
>>Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Rapidly Throttling from Idle to Full Throttle.**
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
