1. Why hisense TV red flashing power light has sound but no picture
There could be a few reasons why your Hisense TV has a red flashing power light but no picture. It could be an issue with the TV itself, the power supply, or the input signal. Let's take a look at each of these possibilities in turn.
2. How to fix hisense TV red flashing power light has sound but no picture
If your Hisense TV has a red flashing power light but no picture, there are a few things you can try to fix the problem. First, check to make sure that the power supply is plugged in and that the TV is receiving power.
Next, check the input signal to make sure that it is compatible with the TV. Finally, if the TV itself appears to be the problem, you can try resetting it.
3. What to do if hisense TV red flashing power light has sound but no picture
Your LED backlights are bad and need replacing, it's something you can do yourself but look at some youtube vids before attempting to do it, the panel is extremely fragile on this model set, be careful handling it or it will break then the TV is junk and the money spent on lamp strips is waisted. Also match the old strips to the pictures of new ones as this model uses 2 styles of strips, best place to buy them is shopjimmy.com
This model had a lot of backlight issues with the lamp strips being bad, order a new set and install them and it will work again, but be careful handling the panel, it's VERY fragile
Throw it away. Seriously most of the parts will wind up costing more than a replacement set...and you are taking a chance that they will even fix it. Hisense has a poor reputation for customer service and does not make service info readily available. If you do decide to try and repair it....yu probably need at minimum an led driver board...assuming the led is not bad.
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen CLICK HERE to BUY ... I have an LG ...
? 1:48
https://www.youtube.com/watch?v=xI3MpZukKm0
Nov 20, 2013 - Uploaded by After Hours Tv & Pc repair
Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http://bit.ly/ShopJimmy6 Want to ...
I have sound and picture but no backlight. .... how do you replace the back lighting on a led lg tv? ... I have a 42 inch LED LCD combo DVD TV made by RCA.
Dec 28, 2015 - Hi, I have an RCA 32" LED 1080p TV that is less than 2 years old, and it has already lost the video. I can hear sound, and I can see lights in the ...
Sounds like a main board fault. Contact any service technician to make it confirm. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
