It works ok at times have had the tv checked and aerial checked all ok according to engineers but problem keeps coming back i retune tv and ok for a while then problem comes back
As there is no new firmware available for your television and the TV has reach "some sort" EOL, i just suggest you to by a new TV. This model is mostly analog (in recieving signals) and the TXT tv reciever is an old type. The TV is from 08 or maybe 09. The second choice is to by a box which convert the digital signal to analog (or visa versa) and use the hdmi port1. This should remove your problem as the box is taking over your txt tv. In DK we have no more analog channels. As i am in no knowledge regarding your homeland i can ofcourse be wrong hence the tv signals.
B.R.
The web began to take over some of the functions of teletext from the late 1990s, and many broadcasters have ceased broadcast of teletext-CNN in 2006 and the BBC in 2012. The decline of teletext has been hastened by the introduction of digital television, though an aspect of teletext continues in closed caption .
SOURCE: I have a Sony digital TV. Recently had a power cut
Retune of TV sorted problem out - even though I had already done this previously! Problem with transmitter?
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers,
for spare parts and service and
Installation Instructions
as required.
Just Google the manufacturer's name and
follow the links. Make certain you are directed to the manufacturer's
web site as some search engines direct you to other sites and they
charge for the information that is normally free of charge.
I hope this helps.
