Tablets & eReaders Logo
A
Anonymous Posted on May 22, 2015
Why is the storage so different from the Samsung 4, 10.1, when both have same os and supposed capacity?
Iota is tablet from Matricom
Mike M
Level 3:
  • Samsung Master 3,349 Answers
  • Posted on May 23, 2015
 Mike M
Samsung Master
Level 3:
Answers
3349
Questions
0
Helped
686103
Points
16707
Samsung tab 3. Tell me About it and what it is worth?
New, $175. Used. $70.
  • Android 4.1.2 Jelly Bean OS, 1.2 GHz dual-core processor
  • 8 GB Flash Memory, 1 GB RAM Memory
  • Store photos, videos, music, and more with up to 64GB of memory available through a microSD slot and 50GB of free Dropbox storage
  • Camera: 3MP rear-facing, 1.3MP front-facing
You might be able to upgrade the OS to KitKat 4.4 but are unlikely to be able to update it beyond. However, whatever gains you get in performance will pale next to sudden restrictions you find on SD card access. Android Central has users up in arms about SD card issues regarding the KitKat and Samsung. If the apps you like run under JellyBean, I'd not bother to update the OS. Other may choose to root the device.
2helpful
2answers
My Nexus 7 tablet says no updates but is only running android 5.1.1. How do I get it to update to latest android version?
Hi if you're tablet is a 2012 model it will not work with the Android 6.0 marshmallow update......Go to Google search type in HOW TO INSTALL ANDROID 6.0 MARSHMALLOW on your Nexus tablet,..... Cheers
I bought a Kingston 16 GB Micro SD. Is that compatible to my Tab 840. I inserted it and heard the clisck but nothing appeared on the screen . What am I took look for and how do I know it is working?
Go to Settings>More Settings>Storage,
There you should have the new SD Card listed.
You still need to tweak different apps to make sure they store data on this card.
If card does not show up in storage, try the card on a different tab or windows PC. If it does not show there either card may be faulty.
You can also try a different card in your tablet and see if that shows up in the Storage settings
1helpful
My tablet is charging backwards. What should I do?
Optimus dying on charger/charging backwards - Android Forums at ...
forums.androidcentral.com > ... > LG Optimus Series > LG Optimus S
Aug 2, 2012 - 11 posts - ‎8 authors
Lately my Opti s hasn't been charging correctly sometimes it won't charge I tried different chargers and i use three batteries two that are brand ... LG G2: Battery and Charging problem- super annoying.
Apr 27, 2014
Samsung Galaxy S3 charging issue - Page 6
Aug 23, 2013
Galaxy S4 won't charge - Page 5
Jul 2, 2013
Says its charging but it isn't?
Feb 5, 2012
More results from forums.androidcentral.com
Why does my battery percent go down when plugged into ...
Where is my trash bin on my matricom G-Tab Zeta 7" phablet?
the trash cans are often in hide mode until you hold on the icon for a few seconds then it will pop up at the top of screen
How do I get rid of insufficient off my nextbook
Sure you have enough internal memory? If you use an (mini / macro) SD card, you have to install different. On Android 4.x and up it must be possible to install on the SD card, but it could be you need to s something extra. If your tablet is not on 4.1 or higher, please first update the tablet, and se how to install on the external memory.
1helpful
Unlock my matricom tablet
buenos dias tengo problema con la tablet se me bloqueo y me pide el pin para asesar y no lo se
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
