How do I fix my sony compact disc receiver model HCD-CBX1, it recently stopped working.the power button has a red led light that flashes on and off.
I've tried unplugging an plugging back in. front display illuminates momentarily then a click is heard and display's out.power button has red led light that flashes on and off and can't be turned on with power button or remote.I've checked internal fuse and it's good.can anyone give a clue of where to start at? or where to get schematics for this model? Thanks in advance.Joe.
To program a new wall console for your Digidoor 3 to the receiver, follow these steps:
Connect the receiver to a power source and turn it on.
Press and hold the "Learn" button on the receiver for 5 seconds. The LED light on the receiver should start flashing.
Press and hold the "Learn" button on the new wall console for 5 seconds. The LED light on the wall console should start flashing.
Release the "Learn" buttons on both the receiver and the wall console.
Press and hold the "Open" button on the wall console for 5 seconds. The LED light on the wall console should stop flashing and the LED light on the receiver should start flashing.
Release the "Open" button on the wall console. The LED light on the receiver should stop flashing, indicating that the wall console has been successfully programmed to the receiver.
If the above steps do not work, you may need to reset the receiver and try the programming process again. To reset the receiver, unplug it from the power source and wait for 30 seconds before plugging it back in and repeating the programming process. If you are still having trouble, you may want to contact the manufacturer for further assistance.
1. Why hisense TV red flashing power light has sound but no picture
There could be a few reasons why your Hisense TV has a red flashing power light but no picture. It could be an issue with the TV itself, the power supply, or the input signal. Let's take a look at each of these possibilities in turn.
2. How to fix hisense TV red flashing power light has sound but no picture
If your Hisense TV has a red flashing power light but no picture, there are a few things you can try to fix the problem. First, check to make sure that the power supply is plugged in and that the TV is receiving power.
Next, check the input signal to make sure that it is compatible with the TV. Finally, if the TV itself appears to be the problem, you can try resetting it.
3. What to do if hisense TV red flashing power light has sound but no picture
My Sony - Model : HCD-GX 470 . When i turn the power on it is on . Just 30 seconds it turns off itself . I do not know what is going on ? Please show me OR help me to fix it .
I have a SONY compact disk deck receiver
model no / HCD-RG290.
Whenever i switch it on it comes on then automacticaly switches itself back to standby mode & dont know why, can you help?
my e-mail is [email protected]
I have the same problem and have worked past it by turning the unit off, waiting until I hear the mechanism stop completely and turning it back on. Sometimes this works the first time and, more often, I have to repeat the process several times. Eventually everything comes up as it should and the unit functions as it was designed. It doesn't work long, and almost always has to be 'rebooted' the next time I want to use it. Except that it is a great unit when it works, I would toss it on the garbage pile and get something else.
The reason this happens is because it takes about 3 to 5 sec. for the output circuit relay to kick in after power up, im sure at this point is when your receiver shuts off and flashes red. You have a bad output Transister its shorted to ground and the sony's protection circuit kicks in and shuts it down. Unless you are a electronic Tech. you will have to take it in to be repaired its going to be about 120 dollars to repair. Now im assuming your speakers are ok, if you have them hooked up when you do this try disconnecting them and try to power up if it does you have a shorted speaker, but normally Sony just displays overload protection on the display. Im sure you have a shorted Trans. sorry for the bad news good luck.
