Starting from the left side of the screen one third of the way across is a Green Vertical Line One Pixel wide. Halfway or down the center of the screen is a Red Vertical Line One Pixel wide and One third away from the right side of the screen is a Blue Vertical Line One Pixel wide.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
