In general, it is usually safe to use a different brand of dryer belt as a replacement, as long as the belt meets the specifications of the original belt. However, it is always a good idea to check
To determine if a different brand of dryer belt will work as a replacement, you will need to consider the following factors:
Length: The replacement belt must be the same length as the original belt. If the belt is too long or too short, it will not fit properly and could cause problems with the dryer.
Width: The replacement belt must be the same width as the original belt. If the belt is too wide or too narrow, it may not fit properly on the drum and could cause issues with the dryer.
Material: The replacement belt should be made of a durable material that is compatible with the dryer. Some belts are made of rubber, while others are made of a synthetic material.
Compatibility: It is important to make sure that the replacement belt is compatible with your specific make and model of dryer. Some belts may only be designed to fit certain models, so it is important to check the manufacturer's recommendations to ensure compatibility.
If you are unsure if a different brand of dryer belt will work as a replacement, it is always a good idea to consult the manufacturer or a qualified appliance repair technician for guidance. They will be able to advise you on the best course of action and help ensure that your dryer is functioning safely and efficiently.
? 6:23
https://www.youtube.com/watch?v=dFB4vnmADh0
Jun 20, 2011 - Uploaded by Repairs101
How to do-it-yourself instructional on changing the drive belt on an electric ... She wanted to know about replacing the drive beltin her clothes dryer. ..... How to replace tumble dryer beltHotpoint, Indesit, Ariston, Creda, Proline ...
? 9:36
https://www.youtube.com/watch?v=kNJGHyEPiJA
Jan 30, 2014 - Uploaded by how-2-repair.com
How to replace tumble dryer belt Hotpoint, Indesit, Ariston, Creda, .... to get right and the grooves correspond to the drive, so really obvious..
? 5:14
https://www.youtube.com/watch?v=ZXSJlWcZPiY
Oct 25, 2013 - Uploaded by AppliancePartsPros
Buy the new Dryer Drive Belt WE12M29 ... to replace the Dryer Drive Belt WE12M29 on GE, Hotpoint, RCA, Sears, and Kenmore dryers.
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Tumble Dryer Belts How to Repair Home Appliances
This could be a few things. The idler pulley or drum rollers are the likely problem. Both are easy to check and replace. The belt should be replaced at the same time. Here is a couple links that should help Dryer belt replacement video Dryer roller replacement Noisy Dryer
The belt can be replaced as follows. 1 remove top and front of dryer shell 2 belt goes around drum around motor pully then under tentioner wheel 3 replace front and top of dryer (top pops off use a slotted screw driver) Thanx for using Fixya Please take your time to rate me
1. unplug dryer
2. popoff the top off
3. take front off (unscrew)
now you can get access to the belt look in bottom of dryer there is a giude wheel for the belt
4. place belt around drum and pulley make sure you add tenstion
5. replace front and top
