Garden Logo
C
Charlene swanaset Posted on May 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my 318 lawn mower back fires
The engine stalls out back fires out the exhaust then it can be restarted
Rhonda Webster
Level 3:
  • Master 978 Answers
  • Posted on May 28, 2015
Rhonda Webster
Master
Level 3:
Answers
978
Questions
Helped
446473
Points
2917
Charlene: According to https://www.briggsandstratton.com/us/en/support/faqs/engine-backfire-afterfire " What causes a small engine backfire & how do I fix it? Backfire typically occurs when the engine is decelerated rapidly.
Common Causes of Backfire:
  • Lowering engine speed too fast
  • Gasoline, which contains higher blends of alcohol
  • Carburetor adjustment set too lean
  • Muffler construction can induce backfire
  • Higher than normal engine temperatures
  • Some carburetors can induce backfire due to the sensitivity of internal transitional passages
    (This condition cannot be corrected).
Possible Fixes for Backfiring:
  • Lower engine speed slowly
  • Follow small engine fuel recommendations and/or switch to brands with low or no alcohol
  • Adjust carburetor for optimum performance
  • Inquire with equipment manufacturer about increasing air volume to decrease engine temperature"
Charlene: I hope that helps! :)
Charlen
Back firing out muffler stalls under load
Could be a bad exhaust valve seat, sticking exhaust valve and possibly a lean running carburetor which is causing the engine to stall out on loads.
Overfilled lawn mower and now it is will not start.and when i try to start it it start for 2or 3 sec and stall out and oil come out of the exhaust.
Overfilled with gas or oil? More in likely you tilted your mower over to far to the air fllter side. The oil has soaked your air filter with oil. Change the airfilter and wipe spark plug off.Once it fires up it will smoke untill it burns the oil out carb. Remember never lean mower to air filter side..Good luck
Aug 17, 2013 • Garden
I have a craftsman 775 series mower and it fires up fine right on the first pull then slowly dies, I noticed that the throttle isn't holding its position and once it kicks back it dies. Any suggestions?
If you restart it immediately after it stalls will it run for a lot less time then if you leave it for a few minutes?
I'm thinking the needle valve or seat are screwed up by this Ethanol gas and the flow of gas to fill up the Fuel bowl is slower than it should be. I just went through this.
Snow blower dont stay running and back fires
Does it backfire or fire out the exhaust? If it is the exhaust you need your valve clearance adjusted. The carb usually means either a bent flywhell key or a failing ignition coil.
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
Troy bilt riding lawn mower runs when its cold but backfires when it heats up
Sounds like you have a valve that is sticking open when it's hot. If your intake valve is not closing all the way when the engine fires, then it will "fire" back out thru the intake instead of the exhaust valve. You will probably need to have a professional look at it, as valves can be very tricky.
James
Nov 10, 2011 • Garden
Lawn mower won't start with out being jump started . Changed battery. After jump starting mower and while mowing engine stalls while mower deck engaged . If mower deck is shut off before it looses...
HI jLAFORCE 1.
Other possible causes include: Loose, Dirty or Disconnected Spark Plug in Your Lawn Mower: Check it out, clean off debris, re-connect and tighten. Fuel Not Reaching the Engine: Tap the side of the carburetor to help the flow of gas. If this doesn't work, you might need a new fuel filter.
Top 5 Mower Troubleshooting Tips ' Briggs & Stratton
https://www.briggsandstratton.com/eu/en.../top-5-mower-troubleshooting-tips.html
Lawn mower won start Google Search
Bought 2 brand new MTD 3.5 HP 20 inch cut lawn mowers Model #11A - 020B352 Both mowers run until hot then cut out and will not restart only turn over with a squirt of fuel bulb then stall again. Both...
heres a few things to check, make sure that the oil is not over filled, you might have bad fuel,, and check the spark plugs on both to make sure they aren't fouled by fuel, if so,, clean the plug and regap them,
Jun 02, 2011 • Mtd Garden
2helpful
Lawn mower stalls when engine is hot
first thing is to check that plug is not fowling up when hot due to motor burning to much oil.
Jul 25, 2009 • Garden
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
