Be carefull, never use force. Check if you don't try to put in the card the wrong way around. Then check if nothing is damaged inside the memory slot. You need a bright light and perhaps a magnifying glass, because everything is very small. Compare the memory slot with a memory slot from another camera. Watch how the little knobs on the side look. I don't mean the contacts. When the contacts are bent, there is a possibility someone once pressed a memory card in the wrong way around and damaged the contacts and knob to secure the card.
SD and Micro SD memory cards SD and Micro SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts. ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Put the memory card in a pc and change its properties - remove the Read only option. If this doesn't fix it then the card is nearing death and has locked itself to allow you to extract the data from it before it fails completely.
Remove the SD memory card from the camera. Look for the lock switch on the memory card and slide it away from the "lock" position. Re-insert the SD card and all should be well.
SD stands for Secure Digital and was one of the first memory cards to have a physical security lock to protect your data.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
You need 1 mobile phones and a memory card reader.
1) Do _not_ turn off the mobile phone!
2) Remove the Memory Card from the locked phone and put it into a
memory card reader. Create
the directory E:\System\Recogs and copy thc-nokia-unlock.mdl into
this directory.
3) Remove the Memory Card and place it into the locked phone.
The THC-NOKIA-UNLOCK program should start after 120 seconds.
4) Remove the battery. Remove the MMC. Put the battery back and restart.
The Phone Lock has been reset to 12345
2) Remove the Memory Card (MMC) from the locked phone and put it into a
this directory.
The Phone Lock has been reset to "12345".
Option No. 1 is
*#7370# is the code to reset everything, including contacts, sms, emails, all application, everything. But you need the 5 digit security code to do this.
Option No. 2
Since you have forgot the lock code, you can try this thing. Using PC Suit, take backup of your phone contents, then update the phone software.
Option No. 3 Unlock Security Code using Memory Card
Steps to unlock ur sec code. 1. Off Ur mobile. 2. remove battry 3. remove memory card 4. On ur computer and plug in ur memory card. 5. insert ur memory card. 6. unzip the attachment file and place it to ur memory card e:\system\recog 7. now insert ur memory card into ur mobile and switch on the fone. 8. now if it ask for code type 12345 and ur mobile unlocks. 9. Every times u restart ur mobile it will unlock ur mobiles security code.
