SOURCE: jvc digital video camcorder gr-d20ek no power
wipe the contacts with after shave solution or isoprophyle alcohol, this may do some magic
SOURCE: Connect A JVC GR D31 Camcorder to a Computer Via USB 2
Well I'm afraid not the cable don't not come in such of a way either cause they are different type of cable, but what u can do is buy an external fire wire card for yr PC it comes in PCI format for yr desktop PC. because camcorder in these days do not use USB cables due to the cause that fire wire cable is much faster than the USB ones.
SOURCE: my camcorder
Hello!
If the camcorder can be connected to the computer there is big posibility that can be downloaded,
Install all the enclosed softwares into the computer and then connect the camcorder, REfer to the user manual regarding the copying of video to the computer. http://books.jvcservice.com/booklist.asp?Model=GR-SXM37US
and the software please refer here:
http://support.jvc.com/consumer/custrel/index.jsp
may this help!
melnavz
SOURCE: Shows fault E04 remove & reattach battery
Do a search of this problem and you will ind that every JVC owner is having the same problem. I finally got mine "reset" by powering the unit on in payback mode while holding down the "play" button. Then, turn it back off and power it on in the camera mode while holding down the "rec" button. This seems to have reset it and I've not had anymore issues SO FAR!
Good luck with it.
SOURCE: how do I connect my jvc gr-ax25u camera to my tv
I have the same camera. There is a cable that came with the camera. It has what looks like an S-video plug on one end that you connect to the camera. The other end has the AV (white & yellow)plugs that you connect to your TV. Your TV has to (of course) have AV connections in order to connect.
