SOURCE: SONY DVP-S7000 does not play DVD
All reviews that I am reading confirm my belief. It is a 1st generation DVD player and therefore will be hard pressed to play any newer DVDs. Think of it as technology advancing. It's sad but it happens. Even newer DVD players can not play the types of movies being developed today. i.e. BluRay discs. So if you cleaned it and you can play picture discs chances are you're going to have to sacrifice which movies you can watch and search for those it will play.
SOURCE: Sony CX995v "Cannot Play" message on DVDs but plays CDs O.K.
Hi...
The laser goes thru a different lens arraignment for DVDs.
Take it to a TV shop and have them "blow out" the laser assembly with some CO2 and clean the lens.
SOURCE: sony player dvp-cx850d won't read cd or dvds. need to reset
This is not a problem that a reset will resolve. If you can gain access to the lens, try cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, the spindle motor may be defective. This is the motor that turns the disc. Once a disc is recognized as being loaded, the disc is spun up. If it does not get to speed fast enough, it will fail to read.
The bottom line is that without seeing the unit, I can not state exactly which scenerio you have here.
If the cleaning does not resolve the problem, I would suggest you request a detailed estimate from an authorized Sony service center.
Dan
SOURCE: SONY DVD-CX995V "cannot play"
In that symptoms optical block (lens) sounds defective and requires replacement.
Let me know if you want to replace optical block by yourself to provide you more technical info.
SOURCE: Sony DVP-CX995V 400 disc DVD Player wont read DVD-
After variety of different tests and findings I have resolved this issue. It appears that the DVD burner was not in good working order and the DVD player was not at fault. Thanks you to all who answered and responded to my problem. Many thanks.
