Sometimes it's bright, but most of the time it's so dim I can't see much but the white startup popups. Irdk what it is. Am confuzzled
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
I have the same laptop here is what i did i pluged in an external monitor and made sure that it was the screen bulb that went bad on it by watching the images on the external monitor i knew that a screen had to be replaced so i went to ebay and purchased a used but working mscreen with the bezel and walla! is all working great
I have an Evo n610c and the screen is very dark. You you can the windows background and icons if you look really hard because it is very dim/dark. Plug it to an external monitor and everything is good. So I bought a new screen but the same problem continued. I tried the screen on another evo n610c and it works fine. I was told the problem is the board and that is what needs changing. I haven't done that yet though so I cannot report on that aspect.
have you tried holding down the function key whilst pressing the up arrow ?
