Go to settings, my account settings, or amazon settings and see if there's a place to add payment options. Or see the user manual inside of device settings and options
I always thought accounts were set up by email address and name. Or is it your credit card number you need to update? For that log into amazon.com Place cursor on your account and lists, about halfway down click on Manage content and devices. On far right is settings. Give all the info about your account. At the top you will see the last 4 of current card with a box next to it says. Edit payment method. click that and make needed changes.
Noretta,
Manage Your Fire & Kindle Payment Settings
Manage your content and Devices.
From Settings, select Edit Payment Method below Digital Payment Settings.
Select the desired credit card information, or add a new card, and then click Continue.
Enter the desired billing address, and then click Continue. You will be taken back to theDigital Payment Settings page where you can view your edited 1-Click payment method.
Follow the link below labeled "Help Search Results". It will take you to Amazons help site and give you the same instructions as above but will ask you to log into your account so you can actually do the above process without have to search around for the correct links.
Go to amazon.com Below the address bar you'll see 'Your Account' Hover over that and click your account from the list. It will take you to a sign on screen and connect you to a secure server. From the list find payment methods Under that click manage payment. It will bring up the kindle wallet and you will see your card listed. click the arrow on the right side and then click edit at the bottom of the box that shows your address info. You can then change the expiry date and confirm it. Also check if that is the default payment method.
Try again , Sould have told you why it could not process payment, if New Card , then might be a problem , but if you have Account Card already set up to cover purchases, should noy have a problem. Final might have had problems as to many trasactions at 1 tme.
Go to account settings. Select manage payment methods. Should be able to add or remove card. Contact Amazon at. [email protected] If you have any problems. Ellen
Log in to your Amazon.com account and under "Your Account" click on "Manage Your Content and Devices." The right-hand column at the top is labeled "Settings"--click on that, and then under Kindle Payment Settings you'll see your current card listed, such as "MasterCard ending in *1234" Click next to it, on Edit Payment Method, and enter your new card's details.
